Performance spark plugs?
04-11-2010, 12:39 PM | #1 |
Rep 6,473
I was running at the track yesterday and couldn't even get a decent run due to cylinder 5 & cylinder 6 misfires half way down the track. I'm pretty sure that I either have bad spark plugs or a weak coil. What are some performance spark plugs that I can replace the stock ones with or should I just put OEM plugs back in? Thanks
04-11-2010, 12:54 PM | #2 |
Rep 3,262
From what I read on this forum, no one has found better spark plugs than stock until now...but surely your misfires should be corrected by treating the root cause which you can find at the dealer.
04-11-2010, 07:40 PM | #4 |
M3 counting down
Rep 91
trying out the HKS spark plugs directly shipped from Japan tuners nxt Fri. Appreantly some tuners in JP run the HKS spark plugs and have better result in terms of performance. Well, it is only heard and dyno from the ppl from other side of ocean. will find out myself nxt fri
04-11-2010, 09:10 PM | #6 | |
Rep 6,594
http://www.trademotion.com/partlocat...layCatalogid=0 http://www.trademotion.com/partlocat...layCatalogid=0 |
04-11-2010, 11:46 PM | #8 | |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
http://www.autohausaz.com/search/pro...2@Spark%20Plug |
04-12-2010, 11:31 AM | #9 | |
Rep 6,473
04-13-2010, 05:34 AM | #10 | |
Rep 5,175
04-13-2010, 06:58 AM | #11 |
Rep 7,377
yeah , Former you know the missfires i was getting especially on meth? well those missfires cylinder 5-6 were due to the plugs. Just changed them and the missfires are gone...... at the end i was getting them without meth as well and the car was running when cold on 5 cylinders.... gonna try the NGK from the mini cooper 2008 that a couple of people are running now without issues.
04-13-2010, 07:20 AM | #12 | |
Rep 5,175
04-13-2010, 07:23 AM | #13 |
Rep 7,377
yep when ALL upgrades are on the car i will open a big thread.
04-13-2010, 08:50 AM | #14 | |
Rep 6,473
Former, I know you are heavily modified. Have you ever changed your plugs to aftermarket colder plugs or run into this similar problem? Enrita, did you change them out with stock plugs and have not had an issue since? Last edited by Bimmer This; 04-13-2010 at 09:48 AM.. |
04-13-2010, 10:31 AM | #15 | |
Rep 5,175
04-13-2010, 02:11 PM | #16 | |
Rep 5,175
