Bird pee...
08-29-2005, 05:18 PM | #2 |
Rep 21
What you probably found was bird poo, not bird pee, (birds don't pee). But as to how to remove it, a simple quick detailer would fix that up. Although if it's been there for a while, it probably ate through a little bit of the clearcoat--which is something that can only be fixed by an abrasive polish. I'd suggest using Meguiar's ScratchX to remove the dimple. Good luck. |
08-29-2005, 06:34 PM | #4 | |
Powered By 36DD
341
Rep 7,369
It probably came from a tree....not a bird...pine trees give off that sticky clear "pee" that you described.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
