Throttle reset proceedure on E90?
08-26-2005, 10:55 AM | #1 |
Rep 898
Drives: F90 M5
Hey all,
Does anyone know the correct proceedure for reseting the adaptive throttle on the E90? On the E46 it was: Turn ignition on for 10secs turn ignition off start engine Has this changed for the E90? |
08-26-2005, 11:44 AM | #3 | |
Rep 683
08-26-2005, 12:18 PM | #5 |
Rep 10,373
I do not know. E90Fleet should know.
I earned major kudos when a friend of mine was complaining how his z4 seems sluggish. I reset the throttle and he was instantly transformed back into another happy BMW driver. |
08-26-2005, 03:29 PM | #7 | |
Rep 683
08-27-2005, 05:00 AM | #8 | |
Rep 898
Drives: F90 M5
Resetting the throttle is supposed to put it back into the sportiest mode and many people say they can feel the difference if they reset it every month or so if they have to commute in heavy stop/start traffic a lot. Although E90Fleet has made me dubious of the benefits now... |
08-27-2005, 02:24 PM | #9 | |
Rep 683
08-27-2005, 05:33 PM | #10 |
Rep 3,566
Drives: F30 M-Sport 328i Estoril Blue
i had an e46 323i for 6 1/2 years and i found the engine to exhibit characteristics that you noted above.
it was not a mindset, it was real. some drives it really felt sluggish others it felt flighty. nothing like the e90 response though. anyway we are off topic here and my e90 is fantastic!
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
08-27-2005, 05:49 PM | #11 | |
Rep 10,185
Remember the auto box does have a adaptive feature But anyway lots of factors can cause different behavier from your engine, like the outside temperature, at a specific temp the engine will start retarding the timing and you loose tons of power, let it cool down a bit and all the power is back |
08-28-2005, 06:20 AM | #12 | |
Rep 3,566
it was a manual tranny. the weather never really played a big part in the engine's behaviour, although i am aware of such variables. it was random and it never really bothered me that much as i knew the car's capabilities which, for the most part were quite ordinary and could easily be beated (to the next set of red lights) by many other cars. i never really tried it either. i just enjoyed the engine note though. made up for its shortcomings. as many have mentioned here and no doubt your good self included, bmw is not only about performance alone. the car was 100% reliable and as you no doubt will agree with me, that's the most important point for any car.
08-28-2005, 11:55 AM | #13 | |
Rep 683
03-22-2009, 05:54 AM | #14 |
Always ride naked
Rep 8
I realise this is a very old thread, and maybe my thoughts are not relevant, however this was a very widely discussed and used topic on the K12 website.
The bikes also had an adoptive throttle feature that was reset by disconnecting battery for half an hour, reconnecting, switching ignition on and operating throttle from zero to full twice and then switching ignition off. Now some clever guy decieded to cheat the system slightly you only open the throttle halway, thereby telling the ecu that full throttle is reached at half throttle. Now the ecu been adaptive would eventually correct for this, but this would take a while to happen, but in the mean time throttle response was improved incrediably. Personal thought says that the ecu thinks full throttle is reached and therefore it dumps the extra fuel in, thereby bypassing those lean burn times at part throttle. I did try this on the K and found it worked as claimed. Now the K was fitted with a very fancy system, but I am sure that a system of at least the same sifistication is fitted to the E90 as they were launched at roughly the same time. Will speak to the guys at the dealership in the week and find out if there is a throttle reset similar to the k on the E90. |
03-23-2009, 06:00 PM | #16 |
Rep 959
There was a thread not too far down the page talking about this...
http://www.e90post.com/forums/showthread.php?t=63796 |
03-23-2009, 09:08 PM | #17 |
Rep 2,926
Drives: Cayman GT4, 135i
On the e90's you have to i believe put the key in, without putting the foot on the brake, press on. THEN hold the gas pedal down, with the engine off. You should hear noise from your gear box(I know sounds ridiculous) but it works, and it resets the ecu of any previous "learns' per say.
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
03-26-2009, 01:56 AM | #19 |
Rep 132
I tried the pedal to the metal whilst ignition was on but engine off for about 60 seconds.
I didn't hear a noise as mine is manual but tell ya what - it makes a huge difference and it's definitely not my imagination. Fritzables. |
04-05-2009, 10:49 AM | #20 |
Always ride naked
Rep 8
Just an update on my previous statement. When I was at BMW (for a remote key failure) I asked them to reset the throttle. The D.I.S machine does it without any imputs from the actual throttle pedal, thereby making the half throttle idea on my car, as per the bike, not relevant.
However, on the bikes, the throttles were also reset with the D.I.S and not the battery diconnect and I can personally swear that on the K12 it really worked. Would be intresting to know if it works on the car as well. |
04-08-2009, 06:18 PM | #21 |
Rep 1,088
If it is "adaptive", then it would adjust to the way you drive. Why do you have to figure out a way to "reset" it??? It's a waste of time.
Case closed. Last edited by jpsum; 04-08-2009 at 06:54 PM.. |
04-11-2009, 08:32 AM | #22 |
Rep 82
From a dead stop there is a hesitation when you give it some gas before it gets going. Not just my car but every other one I driven.
Maybe I'll give this a try today see what happens. Update: Put the key in and put the gas pedal to the floor for about 30 secs w/o turning on the car. Made a big difference. The hesitation is gone now and throttle response is instant. Last edited by broker88; 04-11-2009 at 05:49 PM.. Reason: edit |
