1st to 2nd slipping?
04-28-2010, 01:13 PM | #1 |
Rep 5,018
Drives: VALNCYA
recently i felt a slight "slip" when releasing the clutch into gear from a start aka starting off in first.
I depress the clutch I usually rev up to about 1k rpm to get a smooth start as it goes to grab i feel some slip in the rear... it did this with my OEM rims and my Miro M6s. any input? |
04-28-2010, 03:25 PM | #2 |
Rep 5,018
Drives: VALNCYA
really?
04-28-2010, 05:10 PM | #3 |
Rep 6,594
You feel slip in the rear? As in, the car is slipping or the clutch/transmission is slipping? Not sure how you are feeling this during the 1-2 shift if what you're describing is starting from a stop?
I think we're going to need more info here.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
04-29-2010, 09:47 AM | #4 |
Rep 5,018
Drives: VALNCYA
starting off from a stop i feel the clutch/trans go then slipp it only happens sometimes....its really odd and idk if i should do the cdv and see of that fixes it. or bring it in
the dealer will probably be silly adn say "its your M6 rims" |
