How long a crank duration should be in order to classify as "long crank" ?
04-29-2010, 02:48 AM | #1 |
Rep 3,262
Hi,
For some time, when I start the car mostly in the morning, it takes more to start up than it took when it was new. Maximum 1.5-2 seconds though. Is this classified as "long crank" (aka. predecessor of HPFP failure) ? Before, I couldn't even hear the crank, it started right up. I had a software update in March but I don't remember if that's when the prolonged start times begun. Could it be that the new software update from BMW introduces this prolonged crank time in order to protect the fuel pump somehow ? Or could it be the battery ? I have 23k miles and the car is 1.5 years old. Thanks ! EDIT: I have uploaded a video so you can better hear the cranking sequence. Sorry for the crappy (Nexus One) quality. [u2b]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Hvl3nd-hmBg&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Hvl3nd-hmBg&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/u2b]
04-29-2010, 02:53 AM | #2 |
Rep 4,647
most likely hpfp. i doubt if it will be battery at 23k/1.5yr.
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
04-29-2010, 07:52 AM | #3 |
Rep 1,748
I would qualify a long crank to be anything more than 1.5-2 seconds... I've had as long as 5 second cranks (this was before I had my HPFP & LPFP replaced and software updated) With the update and replaced pumps, it starts right up now, I think the longest I've had was about 1 second, other times it starts as soon as the button is pushed.
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
04-29-2010, 08:08 AM | #4 |
Rep 1,519
I thought that that used to be normal as I don't have a garage but then I got my HPFP replaced and it starts right up even being left outside over night, take it in and see what they say.
Retired - '08 E90 335i Sparkling Graphite/Gray Dakota Leather, ZSP, ZCW, ZPP, Navi, ipod, Sat
04-29-2010, 09:21 AM | #5 |
Rep 3,262
04-29-2010, 10:35 AM | #7 |
Rep 870
The longest crack I've had was after days in long term park at below zero and that took 3 or 4 seconds. Other than that in all other conditions, it's always push the button, and the engine fires up. I never had a long crank for the HPFP either, it just went into limp on the highway.
2007 E92 335i / 6MT / Monaco Blue Metallic / Gray Dakota Leather / Comfort Assist / Premium / Sport / Heated Seats / Navi / Active Steering / Active Cruise Control / Park Distance Control / Rear Sunshade / Sirius MODS PicoTray / M3 Steering Wheel / Front OEM Aero Lip / Bimmian Aluminum Pedals / CDV / Ram Air Scoops / Painted Reflectors / HID 5000k / LED Angels / M Perf. Shifter / Euro Light Switch / 8500 x50 / Center Armrest Pouch / JB4 / BT
04-29-2010, 12:07 PM | #9 |
I don't drive fast , i fly very low
14
Rep 358
when i set my procede on Map 1 or Map2 , in the morning i get long crank like 4 seconds or so ,, but when i set it to valet mode ,, in the morning it start really faster .. maybe 1 or maximum 1.5 seconds ,, how can i tell from the procede fuel pressure is OK or not ..?
04-29-2010, 01:23 PM | #10 |
Justin Herass
333
Rep 1,205
My car is at BMW right now for a possible long crank issue. I have the same problem as you, it only takes maybe 2 sec to fire up, but it used to take 1 sec.
Ill see what they do and post up the results.
04-29-2010, 02:35 PM | #11 |
Rep 3,262
Thanks !
04-29-2010, 03:46 PM | #12 |
Rep 1,759
yeah for a little over a month now I've been noticing longer cranks also, at one point I felt the whole car shaking when I went to start it up.
I predict that my HPFP is royally fucked. |
04-29-2010, 04:16 PM | #13 |
Rep 3,262
Did you have a software update lately ?
04-30-2010, 06:07 AM | #16 |
Rep 3,262
Hi,
Here is a video...is this a long crank ? [u2b]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Hvl3nd-hmBg&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Hvl3nd-hmBg&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/u2b]
04-30-2010, 07:33 AM | #17 |
Rep 1,748
Hmmm... I recommend you record your crank time every day for the new week, I counted a 2 second delay... But I would have liked to have seen the RPM's and if they revved up to 1.5k or 2k rpms... while you sit and wait for the initial warm up phase, before settling down to 6-700 rpms.
04-30-2010, 07:56 AM | #18 |
Rep 3,262
That does never happen.
04-30-2010, 10:16 AM | #20 | |
14
Rep 358
04-30-2010, 12:52 PM | #21 |
Rep 2,575
Drives: '73 2002,'18 X5 35d,'17 328d T
No way is that a long crank. I have had my starting cycle expire before. 25 secs of cranking and then it just stops. When you are getting 5-7 seconds then you are having a long crank issue
1988 E28 535is Euro Conversion --- sold 2009 E90 335 6MT --- sold 2003 E39 540iT Msport --- sold |
04-30-2010, 01:12 PM | #22 |
Rep 1,759
