KDS Results...
05-04-2010, 11:58 AM | #1 |
Rep 336
KDS Results...now updated
Here are my KDS results...they are a little confusing as there are three pages...they had trouble making adjustments to the trackrods thats why it was done a couple of times...I think!
Sapphire Black* Darklines* Black Dakota Leather* Heated Seats* Professional Navigation* Xenons* High Beam Assist* Hi-Fi* USB Audio* DAB* BMW Assist* Sun Protection Glass
05-04-2010, 07:32 PM | #2 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
interesting.....where did you get them done?...I might need one aswell...
05-05-2010, 04:20 AM | #4 |
Rep 336
Ah yes I have just noticed, I was reading the originals at the dealer and asked for a copy and it looks like it was enlarged by mistake!...they are emailing me today with originals ...ill post them later
05-05-2010, 08:32 AM | #5 | |
Rep 11
Do you think you could put that in the OP? I've just wasted several minutes trying to make some sense of those read-outs. Cheers
Titanium Silver 325i M-Sport (3L) Auto Saloon
05-05-2010, 12:28 PM | #6 |
Rep 3,923
can anyone explain how the suspension alters itself? the car is bolted together and apart from bending a part of the suspension or steering i dont understand how it can alter
05-05-2010, 01:01 PM | #7 |
Rep 2,834
Things shift mate, metal flexes, joints loosen, components wear. If you take a knock (say over a pothole or something) that could in theory shift a component without bending/damaging it. The holes that things are bolted through have tolerances etc...
05-05-2010, 01:30 PM | #8 |
Jeff
319
Rep 1,451
Hi
I recently had one done on a Hunter machine. The guy has a contract with a couple of local Mercerdes dealers - he does quite a few of their cars with only around 1000 miles on the clock and it's obvious (to him) that they have left the factory incorrectly aligned. Jeff |
05-05-2010, 04:01 PM | #9 | |
Rep 51
Besides, you might find the factory settings not to be optimal anyway, and prefer a different setup. |
05-05-2010, 04:24 PM | #10 | |
LSD - No, you're not seeing things
72
Rep 3,302
For the Honda S2000, a car I know well they have the same issues. Brand new cars are barely within spec, so even new they benefit from a full calibration. The issue is not the absolute values themselves but the cross-values. That is having the smae angles on each end of an axle. Both may be 'in spec' but the left at one end of 'in spec', and the right wheel at the opposite end of 'just in'. And thats where things get a bit messy with the handling, the difference between the two may be quite large in this case. Small cross cambers dont make a world of difference, but cross toe really does. And too much toe in really scrubs the inside edges of tyres on big camber cars like the rears of these. |
05-05-2010, 04:32 PM | #11 | |
72
Rep 3,302
Almost all of the moving joints in the suspension arms have rubber bushings. They give and wear and move about and thats normally enough to alter things. Such tiny adjustments are requred its quite amazing they dont alter more given the state of the roads. Ref the other post about still being out of tolerance, yes the front cambers appear to be very different. However there is no simple answer to this on a car with struts up front. You would have to probably rework the top strut mounts to alter the camber on these cars, and that means a lot of dremel and drilling! |
05-06-2010, 03:47 AM | #12 | |
Rep 8,972
So we don't know how the car ended up after the work was done! The front cambers are only 24 minutes apart, so only undr 1/2 of a degree between them, not perfect but not really an issue on a car like ours IMO. Our front ends are only adjustable for toe, all others are fixed. Whereas the rear is fully adjustable AFAIK. |
05-06-2010, 02:20 PM | #13 |
Rep 540
By way of comparison, here are my results from a BMW main dealer when I had my last lot of runflats replaced (owing to the usual inside edge abnormal wear).
Didn't help though - after 8000 miles my new set of Bridgestones looked like this: Now replaced by non-runflat and we'll see what happens.
Current: Skoda Octavia Scout 4x4 DSG
Previous: F30 318d Sport, R56 MINI Dooper 2010, E93 325i M-Sport auto 2007, E91 320d SE 2005, E46 318Ci Coupe 2002 |
05-12-2010, 05:03 PM | #14 |
Rep 336
Does anyone know why the ride height is omitted from two of them?
