P3Cars Digital Vent Gauge - Can you help me identify this harness?
05-05-2010, 11:27 AM | #1 |
once Treppiede
63
Rep 915
Guys,
I just got a P3Cars.com Digital Vent Boost Gauge from a member on this Forum. He bought it from another member. The gauge kit is brand new, sealed, uninstalled. Can you please help me identify whether or not it came with the 2009+ mounting harness (no ashtray power)? A couple more questions...
-Walter
2013 E92 M3 | 6MT | AlpWhite | SilverNovillo | CarbonTrim | ZCP | PremiumPkg | Alarm
2009 E92 335i | 6MT | AlpWhite | CoralRed | AlumTrim | M-Sport | Nav | Logic7 | Alarm (sold to a friend - still in the family) |
05-05-2010, 12:10 PM | #2 |
Rep 4,764
That looks like the plug and play version to me. I've had both. He is right about the vent slots, don't push on them much or they will snap (ask how I know).
I think you are good to go. The directions are pretty good. I just used a metal coat hanger, cut and angled to push the boost line through the rubber boot into the engine bay. Then I grabed it in the engine bay with a pair of long handled pliers. |
05-05-2010, 12:22 PM | #3 |
INSTAGRAM: @yaasplease
166
Rep 1,023
Yup, right kit. Only thing with cars that do not have ash trays is that you have to route the power wire through the base of the center console. The easiest way is to remove both panels above the foot well. You will then find a clear path just above the carpet covering the drive shaft tunnel and just before where the center console starts. Fish the line across with a coat hanger too.
I don't know where to plug in the green harness though...
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor 2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out |
05-05-2010, 12:24 PM | #4 |
166
Rep 1,023
Not sure if I am looking at it correctly, but it looks like your front cover is in two pieces? Mine came in one solid piece.
05-05-2010, 12:37 PM | #5 | |
once Treppiede
63
Rep 915
Scottp999 and redfox: Thanks for the replies.
Yes, it is PnP, but I wanted to make sure the power harness was the one for newer models without ashtray power. I have cigarette-lighter style power in two spots: center console and near the glove box. I am still trying to understand where I will have to get power from. Quote:
Thanks! -Walter
05-05-2010, 12:41 PM | #6 |
Rep 610
Read through the groupbuy section to find the gb that was occuring with Rixst3r/P3cars. You will get a better idea of others install procedures. Are you connecting to a proceed/jb3? If so let me know as I just did that and there are some caveats to that that are not discussed in documentation out there. If just the gauge, it should be straight forward. I'd contact the OP on that groupbuy thread i mentioned. He will be able to identify your version better than I. It's pretty straight forward if watching the video install. Be careful with the glass front and putting in the splitter for the boost line. Some have had issues where they snapped the Y boost line adapter so just handle it like it's your dick and you won't snap it.
Oh, the button was loose to me to and once installed with the glass front it still feels loose, but it's not going to fall off kinda loose. |
05-05-2010, 12:42 PM | #7 |
Rep 610
ditto, check and see if it broke right away. It should be one continuous piece. i'd imagine if it broke you may need a new one unless you want it to look jank.
05-05-2010, 12:50 PM | #8 | |||||
once Treppiede
63
Rep 915
-Walter
05-05-2010, 12:56 PM | #9 |
LINEITUP
58
Rep 725
if you have the version with no ashtry, this thing is a bitch to install ... i know. Rixx tells you to follow the 135 directions but those are misleading since the lighter they want you to connect to is part of the center console.. so now you havto to remove it all.. They shoudl REALLY update their site and make a PNP kit..
Goodluck , btw i had to run the power wire to the fuse box for it to work. sucks. |
05-05-2010, 01:22 PM | #10 | |
once Treppiede
63
Rep 915
-Walter
05-05-2010, 02:30 PM | #11 |
Rep 4,764
Don't fret. The center console is not that bad to get into. Also, if you want to tap a fuse in the fusebox, that's not to bad either and you will learn a little more about the car be doing either one.
Rick is a great guy, shoot him a pm for advice! |
05-05-2010, 04:04 PM | #12 |
LINEITUP
58
Rep 725
^ i shoot Rixx a email like 3 weeks ago when i did the install and never got a respond back. Has to figure it out the hard way.
Great product just not great customer service. |
05-05-2010, 08:51 PM | #13 |
274
Rep 6,510
Sorry guys, been a bit busy... my wife and I had a baby boy 2 weeks ago and my wife has been in and out of the hospital with some complications.
I notice a few things about this kit, and will clear up the comments that I see are invalid. being that you purchase this unit SECOND HAND, you are at the mercy of the person you bought it from, which, from the look of the papers and parts, they were pretty rough on it. 1. Your faceplate is broken in half. 2. The PNP harness in your pack is for pre 2009.5 cars, we have a NEW pnp harness for cars without an ashtray (http://www.e90post.com/forums/showth...t=2009.5+power) Regardless of what people say, the new harness is super easy if you read the part on the support site about running it to the new power socket in the passenger FOOTWELL (next to the glovebox), NOT the center console... some people must have missed that... other than that change, the power harness installs like the 135i... 3. It is the newest, latest version... no updates since. 4. If you see all 4 black dots in place around the base of the button stem, and it has not been broken, then you are fine. If you are the 3rd person to get this unit after it was re-packaged twice by people that were not as careful as we are, then the button could have been broken. 4. E-mail me direct at rschilg@gmail.com for faster response since I am stuck at home on baby duty Last edited by RiXst3r; 05-05-2010 at 09:02 PM.. |
05-05-2010, 08:53 PM | #14 | |
274
Rep 6,510
The website has always said: *for install on cars with NO ASHTRAY, please follow 135i instructions for power/dimmer, 335i uses the new power socket in the passenger footwell. |
05-05-2010, 08:58 PM | #15 | |
274
Rep 6,510
I think anyone here would attest to our outstanding level of customer service! We really put that at top priority! |
05-05-2010, 10:44 PM | #16 |
once Treppiede
63
Rep 915
Rick,
I appreciate your timely and thorough reply. Congratulations on the baby and best wishes for all complications to be resolved quickly and painlessly. I read your response carefully and everything makes sense. I will email you right now with inquiries about the new harness and a replacement cover. Thanks! -Walter
05-09-2010, 10:22 AM | #17 | |
once Treppiede
63
Rep 915
Hey Rick... while I wait for the correct harness and new faceplate, I started taking apart what I could and get everything ready to go.
Please let me know so I can start taking apart the panels and look around for the cleanest possible route to run the harness. Thanks! -Walter
05-09-2010, 03:51 PM | #19 | |
274
Rep 6,510
It's just like the normal 335i wiring route, only you have to go a bit further and remove the couple screws holding up the passanger footwell cover to get to the back of the socket and tuck the wires down there... and then of course the 135i install shows you how to hook up the green(dimmer) line.
Obviously this is not ideal, we are going to update the instructions when I get some time, out of the hundreds and hundreds of gauges sold, only 5-6 have needed this alternate harness... but I definitely plan to document it better, soon, as it will only increase in the number of people that need this. -Rick Quote:
05-09-2010, 03:53 PM | #20 |
274
Rep 6,510
09-05-2010, 04:41 PM | #21 |
Rep 825
Bump
So we can mail back the old harness and you will mail out a new harness?
If we (2010) use the old harness, will everything work except for the dimmer?
Down for Maintenance
