Confused about the Xede
12-01-2006, 10:02 AM | #1 |
Rep 45
First and foremost I have read the Sticky!
I keep reading about Shiv traveling all over the place to tune various 335s. I thought when you order the Xede, it's already been tuned to your desired specs based on the mods you have and the octane you run? Don't you just plug it in (so to speak ) and go? What am I missing? |
12-01-2006, 10:07 AM | #2 |
Expert Road Racer
59
Rep 1,329
The facts that:
1) A custom tune, exactly for your car and your typical gas, will extract a few more ponies and make the mappings more spot on...and 2) The Xede is still being developed |
12-01-2006, 10:11 AM | #3 |
Rep 114
Not sure how Shiv plans on doing it with the 335, but considering that the Vishnu website is not updated with a 335 map and install process.. I would have to assume it come preloaded with a base map.
My guess is that he is doing custom tunes on all of the initial 335's to see what is a good margin of safety when creating base map. Once he has everything sorted out, I would hope that it would be posted online for everyone to work on as they please. |
12-01-2006, 10:32 AM | #4 |
Rep 45
So if that's the case then you should have the following 3 options when you order correct ?
1. Specify your mods and octane and order just the XEDE, you will not a get a total custom tune, but very close. 2. Order the XEDE and the software, (this will definitely cost more) and you will need to be competent enough to do your own tuning. 3. Order just the XEDE and if your mods ever change you need to send it back to Shiv and have it relashed (not sure what this kind of charge there would be for this.) |
12-01-2006, 10:48 AM | #5 | |||
Rep 114
12-01-2006, 10:56 AM | #6 |
From Russia With Boost
37
Rep 1,076
Very good questions and from what i know, the responses seem accurate aswell.
Ill see if shiv approves the responses and put them in the FAQ. Thanks guys.
2007 BMW 335i - Delivered 9/8/06
Sparkling Grpahite with Black Leather/Aluminum Trim Premium Package, Sports Package, Comfort Access. |
