JBDiesel Dyno Results
05-06-2010, 03:05 PM | #1 |
Joint Chiefs of Staff
4927
Rep 116,037
BMS was able to dyno a 335D testing out the new JBD quick install tune. No easy way to get a tach pickup on the car so we get MPH/Power only but the gains were very impressive. Stock it did a best of 245rw and tuned a best of 308rw. Also some runs at lower settings for comparison.
This is going to be a hot product for BMW diesel fans. Price will be $279 and testing should be wrapped up in another 3-4 weeks. I will post up a pre-order list soon so stay tuned for more info EDIT - NOW AVAILABLE For more info and pricing! http://www.e90post.com/forums/showth...66#post7877566 Mike Last edited by Mike@N54Tuning.com; 08-23-2010 at 12:43 PM.. |
05-06-2010, 03:08 PM | #2 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Very nice!
I would definite buy a product like this if I had a Diesel.
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
05-06-2010, 03:18 PM | #4 |
Rep 2,485
Holy crap. Show me the torque curves.
My F30 is going to be a diesel!!
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
05-06-2010, 03:56 PM | #6 |
Modder Raider
760
Rep 8,633
Drives: M3
Congrats on finally getting something out there for the D.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
05-06-2010, 04:56 PM | #9 |
Rep 6,595
wow, nice results Mike/Terry...
That's pretty sweet. |
05-06-2010, 06:10 PM | #11 |
Rep 1,517
Drives: Ever changing fleet
Tough to achieve on a dyno. Most use inductive pickups on the ignition to get a tach signal. No ignition on a diesel
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
05-07-2010, 10:23 AM | #13 |
Rep 710
A nice improvement. But I suspect, still not much of a match for a tuned 335i.
http://www.insiderpicks.com - The world's best stock picks.
05-07-2010, 11:08 AM | #14 |
Redline Addict
21
Rep 783
05-07-2010, 12:05 PM | #15 |
Mad Linux Guru On The Loose
1131
Rep 5,404
Very nice indeed especially if this is all stock with just JBD!
Some things I'd like to point out: 1. Unlike petrol engines, the more you modify diesels, the more efficient they become! 2. Perhaps the single most important upgrade for the diesels will be an aftermarket intercooler. Since diesel continues to be injected even during the downward stroke after ignition occurs, having colder, thicker, more oxygen rich air into the engine will drastically increase performance and fuel efficiency. ...and a question: does anyone know if the 335D has an EGR valve? If so, where does the exhaust gas get re-introduced into the intake? Before or after the intercooler? |
05-07-2010, 12:44 PM | #16 |
Rep 60
I look forward to putting a JBD on my 335d!
The 335d uses what BMW refers to as a high pressure EGR system, meaning the exhaust gases are injected in to the inlet at the high pressure point of the intake (throttle body just before the intake manifold) |
05-07-2010, 01:33 PM | #17 | |
1131
Rep 5,404
The reason why I started talking about the EGR system is because it is very critical for the performance of the diesel engine to have clean intake tract. The diesel soot has the tendency to coat any surfaces it passes through therefore clogging pipes, manifolds, etc etc. ... you get the picture. I will not be surprised if semi-annual cleaning of the intake manifold will be a good thing to do on the 335D. |
05-07-2010, 04:17 PM | #21 | |||
Speed Demon
209
Rep 3,690
Yes, it is, and there's already an update for this for current/prospective BT buyers.
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i |
05-08-2010, 10:55 AM | #22 |
Speed Demon
209
Rep 3,690
Another note: If you live in SoCal (Riverside/SD/OC) and want to get a feel for it, let me know.
