tire presure monitor
05-06-2010, 07:29 PM | #1 |
"J" BONE
24
Rep 578
i have a 2007 335i and i was told that in canada the 2007 did not come with tire pressure monitoring system..this true?
procede v5 rev3, afe dual cone intake, full catless exhaust with muffler delete, hm style carbon fibre lip, 235/35/19,275/30/19 satin black linea corse818, H&R sport springs, Vishnu charge pipe with forged diverter valves, matte black kidneys, mtec superwhite angel eyes and fogs, bms cdv ER fmic, VRSF coated DP. Vishnu pwm meth kit
05-06-2010, 08:25 PM | #2 |
Rep 7,148
mine is an April build 07 and i have tire pressure monitors
2016 F80 M3 Mineral White/Sakhir Orange
2013 BMW S1000RR Flat Silver <stolen> 2007 BMW E92 335i Jet Black/Jade Grey <sold> |
05-06-2010, 08:53 PM | #3 |
"J" BONE
24
Rep 578
ok so what does it mean when your tire pressue monitoring system light is on and lit in red..i filled all my tires to about 35 psi and reset the system...light still on and none of my tires leak..plz any info would be awesome
05-06-2010, 09:36 PM | #4 |
Master of Everything I See
Rep 138
Did you recently change from Snow tires to your summer tires? My 2007 is able to measure the tire pressure. If your snow tires had a different level of pressure than your summer tires then all you need to do is reset it. Even if you changed the pressure on the set of existing tires you will need to reset the Tire Pressure system on the car, it's easy just look it up in the manual.
05-06-2010, 10:25 PM | #5 | |
"J" BONE
24
Rep 578
05-07-2010, 01:32 AM | #6 | |
Dreamer
34
Rep 837
http://www.e90post.com/forums/showthread.php?t=36772 Also there is a diff between what Canada and USA uses. FTM - Flat tire Monitor TPMS - Tire pressure Monitoring System (as you already know.) |
05-08-2010, 10:20 AM | #7 |
AWD Turbo Lover
Rep 16
Not that it helps with a 2007 since I have a 2008 335xi coupe but ...
I was told I had TPMS when I picked up the car at the dealer so I would have to keep that in mind when I purchased winter tires for itand that I would have to reset the system whenever I traded over from summer to winter or back. So I added sensors when I purchased my winter tire/wheel package from Tirerack. This year when I removed my winters I went to a 19" wheel and planned to move the sensors from my original factory tires to the new tires. Imagine my surprise when the tire shop called to say there were no sensors in the factory tires. They put the new tires on without sensors. One of the valves was bad and leaking air but I didn't realize. Later that day when driving the tire pressure warning light came on. I stopped, saw the low tire and added air so I could get back to the shop. So it seems that in Canada in 2008 the 335xi (with zsp) did not have TPMS but rather FTM and it works.
| 2008 335xi e92 | Black Sapphire Metallic | Black Dakota Leather | Aluminum Trim | Sport Package | Premium Sound | Comfort Access |
05-08-2010, 02:19 PM | #8 | |
Dreamer
34
Rep 837
05-09-2010, 04:04 PM | #9 |
Rep 200
Drives: 16 X5,06 e91 325ix,03 Mini R50
My 2009 Lci 323i is also FTM.
And I specifically asked the dealer if it had TPMS, which he said it did. Oh well, I guess the well educated enthusiast knows more after all. |
05-09-2010, 05:03 PM | #10 |
"J" BONE
24
Rep 578
sorry bout the dumb question but with the ftm there is some sort of sensors inside the rims? i asking because i didnt get no sensors for my 818 and wondering if i have to get some?
05-09-2010, 08:39 PM | #12 |
Rep 797
Drives: E92 335, E36 Ti, Porsche 986
The ftm measures changes in the diameter of the wheel by it's rotation from a sensor in the brake. Canadian 2007s had ftms. you'll have to reset it when you change wheels or tire pressure.
Monaco Blue E92 335 - i-Forged Senekas, KW V2 Coilovers, OEM Bmw Aero lip, AFE DCI, LUX H8
Sublime Green Dodge Challenger 392 w/hellcat package. KW Coilovers, Speedlogix CAI Jet Black E36 Ti - E36 M3 drivetrain, Full M-Tech, H&R Coilovers, 3.73 LSD, M-Clubsport interior and much more... |
05-09-2010, 10:29 PM | #13 | |
Dinan 2
Rep 91
This is nice because you don't need to buy TPMS when replacing wheels and you can easily run Non Run flat tires (just make sure you have a tire repair kit with you). |
05-09-2010, 10:51 PM | #14 | |
Rep 3,868
Drives: E93 335i
Did you correctly re-set it ? You actually have to hold the button for at least 5 seconds in Tire Pressure set mode.... until the check mark appears appears in the box.
12.770 @ 112.81 mph||slip||JB4|FMIC|DPs|DCI|N54 DVs|ER CP|Koni FSD|Eibach-Pro|F Strut-bar|R Sway-bar|Hankooks V12|DPE SP16|BBK|15%Tint|CF Front Lip|CF Diffuser|M3 Spoiler|SmartTop|LUX AE|Debadged |
05-10-2010, 06:59 PM | #15 |
"J" BONE
24
Rep 578
hmm ok i try that... thanks man...but bmw said i might need to be re initialized is this true possibly
05-10-2010, 08:53 PM | #16 |
Rep 1,938
05-10-2010, 09:36 PM | #17 | |
Rep 3,868
Drives: E93 335i
That's all I do when I switch my winters/summer tires or after putting air into them....
05-10-2010, 11:25 PM | #18 |
"J" BONE
24
Rep 578
awsesome thanks for the advice ...they told me to press the button not hold it......
05-10-2010, 11:26 PM | #19 |
Rep 2,740
05-11-2010, 01:21 AM | #20 |
Rep 3,868
Drives: E93 335i
Missed that step, thanks...
Actually all this info on how to re-set tire pressure is in the manual
08-30-2010, 02:16 PM | #21 | |
Rep 2,517
Drives: '11 335xi e92 M-Pak
I was checking some winter tires at Tire Rack and they suggested to get the TPMS since our car apparently comes with it. It cost $212 for 4 sensors and valve caps! |
08-30-2010, 02:24 PM | #22 |
Rep 155
If the valve stems are metallic, then it's TPMS, otherwise it's FTM (so there is no sensor in the wheel, instead the ABS sensor is used to measure the rotational speed and determine if you have a flat or not).
The FTM system needs to be initialized as per the manual. My 2007 E92 did not have TPMS, my 2010 E90 doesn't have them either. I was told at the dealership that the Canadian models do not have TPMS and my history confirms it. |
