BIMMERPOST Universal Forums Off-Topic Discussions Board need help with wireless network
      12-01-2006, 10:17 PM   #1
txusa03
Drives: TS330iPPSP6MT
Guys/Gals, I just got att dsl w/ wireless router (att 2WIRE router). My questions concern security/encryption. I think the att 2WIRE comes default with a firewall. The wireless connection is secure. I also have another firewall (PC-cillin Internet Security) running. Is this overdue or can I delete some firewall? I like to be able to do online banking and I just want to make sure I do not make it easy for any sniffer to grap my info.
I am using 64-bit HEX value WEP encryption and is it good enuf? What is WEP anyway? Anyone use att 2WIRE and how you set your encryption up?
Thanks in advance for any assistance.
under construction!
      12-01-2006, 10:25 PM   #2
just4kickz
boku no namae ha...
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
2006 E90 330i  [0.00]
you can never have too many firewalls... and plus all firewalls are made to be broken so dont sweat it... the average person with a firewall on the router and a firewall on the computer should be fine.
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!"
      12-01-2006, 10:34 PM   #3
Ninjaneer
Shadow Warrior
Ninjaneer's Avatar
Drives: '07 335i Sedan
If you're sure it has a good firewall and you're not getting hit with random junk then you might be ok. If you have XP then you could just use Xp's built-in firewall if you don't want to deal with PC-cillin.
Personally I have a LinkSys and its firewall has served me pretty well, and I don't run any extra firewall s/w beside it.
WEP (Wired Equivalent Privacy) encryption at 64 bit should be alright. Apparently WEP is easy to crack but it's still widely in use and is good enough to deter simple snooping. Something I read up on Wikipedia heh...
Generally the higher bit encryption you go with, the longer the key and harder to crack, but more encryption means less speed performance. It might not make that big of a difference on a home network for you to notice. I use WEP 64bit at home and it's done a good job.
If you can set up your own SSID and network name these help too rather than keeping them at default settings.
Maybe someone else has more detailed info / experience to offer
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods:
PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar
Installing soon: Rear Power Outlets (Happy Robot mod!)
      12-01-2006, 10:35 PM   #4
txusa03
Well the draw back to firewall is it slow down network. I am getting 54 Mbps and that is slightly better than 56K. But I can feel the firewalls are causing a slight delay when I surf my favorite e90 forum. I also forget to attached this pic.
under construction!
      12-01-2006, 11:51 PM   #5
just4kickz
boku no namae ha...
uhh how is 54mbps slightly better than 56k... 54mbps is just the highest possible speed for your internet transmission... if your on dsl or cable which is like 200kps+ it shouldnt matter that much. 56k is just ur modem max speed... but most people wont get 56k anyways
      12-02-2006, 07:14 AM   #6
bimmer4me
bimmer4me's Avatar
Drives: 2006 330i
2006 330i  [0.00]
56k = 0.054mbps. So yes, 54mbps is 1000 times fast than 56K speed.
Most cable internet speeds run around 0.9mbps - 1.4mbps. That is going to be your bottleneck. There definitely is a some performance hit when doing WEP, but you really want to do it nonetheless.
You only need 1 firewall at home. The firewall in your router is hardware based and therefore faster. Turn off the Windows firewall you'll see a speed improvement with no downside in security.
2006 330i Monaco Blue | Grey | Walnut
...Manual | Sports | Premium | Cold | Nav | Comfort Access | PDC | Sirius | Sunshade
...M-Tec Steering Wheel | M-Tec Shifter | TLC
...Performance Center Delivery | Oct 14, 2005
      12-02-2006, 07:24 AM   #7
bimmer4me
bimmer4me's Avatar
Drives: 2006 330i
2006 330i  [0.00]
Typically, you have to tell the router what the WEP key is and then put the same key on your computer. From the screenshot, you know how to enter in this key on you computer. Look in the router's user manual for a web address that will look something http://192.168.1.1. That should bring up an admin screen where you can fish around for the WEP key setting.
      12-02-2006, 07:47 AM   #8
txusa03
I dont know that is what someone told me. I did not understand it either because it was like night and day going from 56K modem to DSL. There are different dls packages that you can get from att as well. I got the cheapest package. Att offer a faster dsl for those who run business at home.
Thanks, I will look into this. But, I just want to point out that when I first connect to the wireless, its prompted me to enter the web key that att already provided to me. So my guess is that att already set this wep key in their router before they shipped their router to me. Hope that makes sense. Lol, btw, att does not have much of a manual on their router.
under construction!
      12-02-2006, 08:03 AM   #9
SGxi
Drives: E90 328xi
2007 328xi  [0.00]
I believe there is a default WEP key in the 2WIRE router (at least in the old one), but you can change it anytime.
MY07 A22 E90 N52Nxi
      12-02-2006, 12:09 PM   #10
just4kickz
boku no namae ha...
why did u get a 2wire? jw i have one at home... i dont like it much... but at my apt i jus use the cable reciever from comcast + a linksys wireless + ethernet hub w/ encryption n' stuff
      12-02-2006, 08:51 PM   #11
txusa03
It was a cheap route to take. They sent me a wireless router. I hook it up to phone jack, voila, I have dsl. I dont need anything fancy but at the same time I want some level of protection cuz I have wireless and I don't want anyone sniffing around for packages.
under construction!
