Modified CDV Comparison?
05-13-2010, 11:36 AM | #1 |
once Treppiede
63
Rep 915
Guys,
Has anyone ever compared the different modified CDVs offered out there? Is it just a matter of buying an OEM CDV and pulling the restrictor or are some vendors also porting the inside? I want to do the CDV delete mod but I would like to get the best modified CDV for optimal flow. I would also like to avoid cheaply drilled unit that might crack. I searched but I couldn't find anything, I understand this is not the hottest topic but any insight is greatly appreciated! Ciao, -Walter
2013 E92 M3 | 6MT | AlpWhite | SilverNovillo | CarbonTrim | ZCP | PremiumPkg | Alarm
2009 E92 335i | 6MT | AlpWhite | CoralRed | AlumTrim | M-Sport | Nav | Logic7 | Alarm (sold to a friend - still in the family) |
05-13-2010, 11:49 AM | #2 |
foxfire74
Rep 32
I got mine from Zeckhausen Racing
Here is why I didn't mod mine myself:
We do not drill these CDVs, as some have suggested. Drilling enlarges the openings on the tapered seats at each end, causing leaks. Drilling may also result in loose bits of metal destroying the seals in your clutch slave cylinder. We have developed a technique for removing the guts of the valve without damaging the tapered seats that allow these valves to seal properly. To avoid the risk of a hydraulic leak and subsequent clutch failure caused by modifying your own CDV, you can have one modified by Zeckhausen Racing. |
05-13-2010, 12:04 PM | #4 |
Rep 732
the 'technique' is a 5mm round bar or hex key, and a firm push or toy hammer will do the job. The body is made of plastic and has quick release fittings. It is not a 1000+psi high tech device.
And there's a good reason not to make it any larger then it is (and larger then the rest of the piping) as that would create an area from which you would never ever bleed the air |
05-13-2010, 01:16 PM | #5 |
once Treppiede
63
Rep 915
Cool, thanks for the info guys. I knew I could remove it and plug the line back in without it, but I wanted to retain the factory look like most people.
Thank you, -Walter
05-13-2010, 02:20 PM | #6 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
I recommend buying a premodded one like that from BMS rather than modifying it yourself....or just remove it completely as mentioned above.
05-13-2010, 11:20 PM | #7 |
N54 FTW!
25
Rep 389
There's no drilling needed, simply remove, put it vertically on the bench with the loose washer side down (you'll see the restriction is just a washer inside). Put a punch or Phillips screwdriver in and a couple taps with the hammer and it just pops out. No drilling required and doesn't destroy any of the couplings or seals.
05-13-2010, 11:53 PM | #8 |
Rep 39
I installed the BMS CDV, and have noticed a big difference from stock. It was a huge pain in the ass to install on an XI (drive shaft in the way), but I am very pleased with the results!
05-22-2010, 08:57 AM | #9 |
Rep 363
ok so I am looking at the Modified Clutch Valve on n54tunings site because I finally plan to get the powerbox soon. Please school me on the Modified Clutch Valve and the benefits.
2004 Silverado CC 4x4 2007 Kawa Zx10r |
05-22-2010, 06:49 PM | #10 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
I just got the M3 "CDV" from Tischer, which doesn't have the restrictor. Part number 21522283914. It was about $14 shipped.
You could also get the pre-modified ones or knock out the restrictor yourself. |
05-22-2010, 09:25 PM | #11 | |
Rep 572
05-23-2010, 10:46 AM | #12 |
Joint Chiefs of Staff
4927
Rep 116,037
We sell them for 20.00 so I usually recommend just buying a modified one but if you want to save 5 bux or so you can mod one yourself. Not sure how much they go for at a local dealer, but Tischer is a good bet to order a stock one.
Mike |
05-23-2010, 10:59 AM | #13 |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
remove it completely..
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
