BMW Yaw Control
05-13-2010, 12:29 PM | #1 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
BMW Yaw Control
Does BMW use Yaw control? From my research it does it by applying it by ABS.
After driving around for sometime in a tuned BMW, sometimes when something goes wrong the cars computer will kick in but the tune will still behave the same. Will a tuner incorporate or read yaw control to then apply boost whenever needed?
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
05-13-2010, 12:47 PM | #2 |
The Stig
31
Rep 1,232
Huh? DSC will attempt to control yaw in case of a slide by modulating the brakes at all four corners. Find a big open parking lot in the rain and try to slide it, you'll see.
As far as being related to tunes, I'm not even sure what you're asking?
05-13-2010, 12:50 PM | #3 |
Rep 2,663
Will a tune lower boost or turn off completely when DSC is involved controlling YAW?
05-13-2010, 12:54 PM | #4 |
The Stig
31
Rep 1,232
I am fairly certain this is a throttle plate activity, but the short answer is probably "it depends on the tune"
05-13-2010, 01:53 PM | #5 |
Rep 126
I was under the impression that active yaw control had more to do with normal cornering and body roll, and how the outside struts would adjust to compensate for the cornering inertia? not neccessarily when the user input is demanding sharper turning angle than the car can deliver, triggering dsc
05-13-2010, 02:16 PM | #6 | ||
Rep 2,663
05-13-2010, 02:38 PM | #7 | |
The Stig
31
Rep 1,232
As I said above, I believe DSC "yaw control" is done with independent braking.
05-13-2010, 03:11 PM | #8 |
Rep 2,663
Shiv will you incorporate this in the future of the Procede?
05-13-2010, 03:56 PM | #9 |
1750
Rep 17,960
Drives: A Lot
Ya... definitely not going to get involved traction control related stuff.
05-13-2010, 05:38 PM | #10 |
Rep 3,004
05-13-2010, 05:43 PM | #11 |
1750
Rep 17,960
Drives: A Lot
We'll still to exposing ourself to the acceptable problems ("hey, my SES light didn't blink when I switched maps!") than bad ones ("hey, I crashed my car into a tree because the traction control applied too much brake to the rear outside tire!")
05-13-2010, 05:56 PM | #12 |
Rep 2,663
Not at all what I meant on the traction side. Basically have the tune read what the traction is doing and adjust boost and features that the Procede supply.
05-13-2010, 05:59 PM | #13 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
05-13-2010, 06:43 PM | #14 |
Rep 2,014
Do you basically want the car to drive itself? Just take your car to a track (not drag strip) and learn how to drive your car.
05-13-2010, 10:34 PM | #16 | ||
Rep 2,663
Thanks Quote:
I do 100% of my driving in the streets, as probably everybody else. I thought yaw control was the vehicle measuring longitudinal and lateral g forces, steering, brakes and throttle position.
05-13-2010, 10:34 PM | #17 | |
The Stig
31
Rep 1,232
This thread really doesn't make any sense...
05-14-2010, 10:36 AM | #18 | |
Rep 2,014
05-14-2010, 10:51 AM | #19 |
3442
Rep 79,211
05-14-2010, 10:52 AM | #20 | |
Rep 2,663
I've taken track lessons in Europe on different kind of cars(160€+) and difently know how to drive in different situation, cornering, shift points, throttle. BMWCCA here is to expensive.
05-14-2010, 11:52 AM | #21 | |
The Stig
31
Rep 1,232
A real track has turns and requires some skill! Hint: it's what the engineers designed these cars for!
05-14-2010, 12:25 PM | #22 |
1750
Rep 17,960
Drives: A Lot
