PROcede install issue
05-22-2010, 08:12 PM | #1 |
Rep 320
I just installed the PROcede on my car but when i try to turn my car on it
just cranks forever but never starts. There's a couple things to keep in mind though: 1. My car was having longer cranks (3 seconds) a few days ago but it's been getting better and today it was starting/driving fine before I installed the unit. I really don't think my hpfp just failed when it started and drove fine just a couple of hours earlier. 2. I made the mistake of disconnecting the battery for the install and I don't know if that could have caused the issue but I doubt it. Any ideas? Any help is really appreciated. |
05-22-2010, 08:23 PM | #2 |
"Booty Hole Bandit"
32
Rep 1,597
Check the connectors to make sure they are installed into the DME harness correctly and the connections from the DME to the Proceed are facing properly...
2008 Montego Blue E92 335xi - MT - Sport - Cold Weather - Nav - iDrive - PDC - Logic7 - CA MODS: Unknown |
05-22-2010, 08:26 PM | #3 |
Koala012
20
Rep 637
Drives: E92 M3 Dakar Yellow
Just check your all wires and read/watch installation video again.
Did you connect the power wire ? It's not HPFP for sure... check your all wires.
E92 M3 Dakar Yellow DCT | CF Trim
Akrapovic EVO Exhaust | RECARO RS-F SK2 Seat | KW Clubsports | H&R Sway Bar | DCT Cooler | iTG Air Filter | Volk TE37 SL + RS3 Tire |
05-22-2010, 08:29 PM | #4 |
Rep 4,764
This has happened to many people. It is usually the position of the wires in the green power box. Car turning over and not starting is the symptom. In the install video the box is twisted/turned at some points and it can be confusing what is front and back.
** Read this thread. My first post there is #17 - http://www.e90post.com/forums/showthread.php?t=369255 Last edited by scottp999; 05-22-2010 at 08:34 PM.. |
05-22-2010, 08:44 PM | #5 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Happened to me. Just unplug all connectors and plug them back in with the battery disconnected. Plug battery back in and it should work fine. Clear all codes when completed.
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
05-22-2010, 09:21 PM | #6 | |
Rep 572
05-22-2010, 10:23 PM | #7 |
Rep 320
Thanks for the help so far guys, I checked the power box but it seems right, the PROcede cable is plugged into slot 2 on the side that we change, and the other one is in slot 8..I'm going to keep looking over the connections and maybe just re-plug them
05-22-2010, 11:07 PM | #9 |
Koala012
20
Rep 637
maybe reprogram it ?
reload firmware and map. see what happens. I still think there is something wrong with wires if your engine doesn't even start. maybe dead battery ? if you really think all wires are correct, use jump cable ? Just my thought.. email sales@vishnu . They will help you.
Akrapovic EVO Exhaust | RECARO RS-F SK2 Seat | KW Clubsports | H&R Sway Bar | DCT Cooler | iTG Air Filter | Volk TE37 SL + RS3 Tire Last edited by ala012; 05-22-2010 at 11:13 PM.. |
05-23-2010, 01:11 AM | #10 | |
Rep 4,764
Did you buy this procede new or used? Is it Rev1 hardware or rev 2? |
05-23-2010, 01:18 AM | #11 |
Koala012
20
Rep 637
+1 what is red connector ?
05-23-2010, 03:35 AM | #12 |
1750
Rep 17,960
Drives: A Lot
The red connector is for progressive methanol. All the harnesses now come with that update. Just ignore it (unless u run meth of course).
05-23-2010, 07:59 AM | #14 |
Rep 4,764
Bump for update. If you put it back to stock, does the car start right up? Probably best thing is to go back to stock and verify it starts, then start the install again and go slowly.
05-23-2010, 08:31 AM | #15 |
Rep 7,377
you totally messed up the wiring and installation, +1000 on the comment above.
05-23-2010, 01:46 PM | #17 | |
3442
Rep 79,211
But yea its def a wiring issue. You also need to make sure all connections are seated fully and the arrows are opposite on the plug. If you see arrows on one side ONLY then its backwards. Last edited by Jeff@TopGearSolutions; 05-23-2010 at 06:10 PM.. |
05-23-2010, 02:09 PM | #18 |
Rep 320
UPDATE:
Wow it was a simple mistake I didn't fully push in the two ecu connectors...Car started up great. Test drive coming soon, after I put everything back! Really appreciated for the input for everyone that helped, I made the thread expecting maybe one or two responses but got so many more..this really shows how good of a community we got here. |
05-23-2010, 02:38 PM | #19 |
1750
Rep 17,960
Drives: A Lot
Bueno
05-23-2010, 02:41 PM | #20 | |
Rep 1,883
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
05-23-2010, 03:43 PM | #22 |
1750
Rep 17,960
Drives: A Lot
