BMS DP Fix
05-22-2010, 10:53 PM | #1 |
Rep 15,818
BMS DP Fix
Currently, my 02 fix is installed through my Jb3
But I want to remove my JB3 I looked here: http://burgertuning.com/instructions/BMSdownpipefix.pdf Seems I must use the JB3? I can't install it without the JB3? Did a search but can't seem to find a DIY... Thanks
05-22-2010, 11:01 PM | #2 |
Rep 15,818
o yeah should have posted in the Turbo Section
My apologies
05-22-2010, 11:15 PM | #3 | |
208
Rep 9,339
05-22-2010, 11:18 PM | #4 |
Rep 15,818
V2
My Friend and I are going to try it tomorrow...
05-22-2010, 11:22 PM | #5 |
208
Rep 9,339
get into ecu
remove the small driver side ecu connector slide the small black sub connector out connect V2 fix wires as follows: white on dp fix- slot 19 on small black oem subconnector Red on dp fix- slot 20 on small black oem subconnector black on dp fix-slot 23 small black subconnector cover up the exposed connections with some tape... test and close her back up |
05-23-2010, 10:50 AM | #7 |
Joint Chiefs of Staff
4927
Rep 116,037
05-23-2010, 10:57 AM | #8 |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
Isn't there talk of the car actually starts to run a bit lean once the code is triggered? I think I've heard it or seen it some where but can't remember.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
05-23-2010, 01:23 PM | #9 | |
Rep 4,936
I actually have the V2 but ever since i uninstalled it i never took out the time to reinstall it.
[SIGPIC][/SIGPIC]
