Hot weather dulls performance?
05-23-2010, 07:54 AM | #1 |
Rep 939
Hi All,
My 335d seems not quite as rapid as it usually is, its still rapid but while the weathers been hot I've noticed that when I "gun it" the world is still in shape and focus, I'm used to it starting to go blurry!!!! I'm thinking that the combined extra load on the air con compressor and the slight decrease in air density due to the heat means I'm not getting quite the same power as when its cold. Anyone else finding this? I did have my turbo boost hose replaced by BMW just as the hot weather started and did wonder if they had reset my ECU and lost my remap http://www.e90post.com/forums/showth...=281232&page=6 Hopefully I'm just worrying for nothing |
05-23-2010, 10:47 AM | #2 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
My one is running ok in London....;-)
05-23-2010, 11:08 AM | #4 |
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
Certainly does dull it as acerboo said, and turbo engines more so in my experience.
Bit like me, I don't fair well in this heat sorry to say. |
05-23-2010, 01:40 PM | #5 |
Rep 64
would definately agree. my 335i isnt as sharp once external temp gets over 20 degrees c. also temp gauge is at 120 - usually sits at 110. it hates london in this weather!
yatin |
05-23-2010, 01:58 PM | #6 |
Rep 336
Yea I would agree my 330d today seemed a bit lazy in 26.0 degrees heat... I will go for a blast later in the cool evening to see if she's ok! I think when you accelerate fairly quickly the ECU drops out the air con compressor to prevent damage during hi-revving acceleration and not to allow it to zap some 4 horsepower from the engine at crucial overtaking moments!!!
Sapphire Black* Darklines* Black Dakota Leather* Heated Seats* Professional Navigation* Xenons* High Beam Assist* Hi-Fi* USB Audio* DAB* BMW Assist* Sun Protection Glass
05-23-2010, 02:19 PM | #7 |
The Tarmac Terrorist
957
Rep 29,345
Drives: 997.2 GT3
Cars deffo will have affected performance in this weather. In start stop traffic you will have heat soak. Which can affect performance also.
Ive seen this at the drag strip. Cars loosing 2-3MPH at the end of the run due to it.
997.2 GT3
05-24-2010, 06:07 AM | #8 |
Rep 15,858
Heat soak is a bigger issue than most believe, it takes a bit of constant driving to get rid of it as well, once soaked. So any hard acceleration from a 'stop start' situation will be more noticeable, than the same acceleration from running through the air at the same ambient temperature.
HighlandPete |
05-24-2010, 06:20 AM | #9 |
Rep 104
As mentioned previous - you will drop power due to the air density changing (decreasing) with ambients.
The power loss will vary engine to engine (realistically 20ps or so), however on the plus side your car would have lost aerodynamic drag in the warmer ambient air... |
05-24-2010, 08:08 AM | #10 |
Rep 1,071
+1. Warmer air = lower air density = decreased performance.
05-29-2010, 01:08 AM | #12 |
Rep 104
