2 turbos better than one?
05-24-2010, 05:48 PM | #1 |
Rep 549
Hello,
What are the drawbacks and bright sides of having 2 turbos? What are the drawbacks and bright sides of having 1 turbo? Cheers! |
05-24-2010, 05:52 PM | #2 |
Rep 3,004
depends on the application....size of turbo, size of motor, purpose of motor (top speed vs quick spool/acceleration), # of cylinders....list goes on. Kind of like asking if two testicles are better than one.....Apparently one is better when it comes to winning bicycle races hmmmm in that case, two are usually better than one, it's good to have backups
05-24-2010, 05:58 PM | #3 |
Rep 549
Well, I like having two testicles...and really don't want to settle for one ;-)
Anyhow, seems like a lot of people like the idea with one turbo and I don't understand why, unless it's for cost savings when upgrading your turbo(s). |
05-24-2010, 06:02 PM | #5 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
I say two. But again, depends on the application...
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
05-24-2010, 06:24 PM | #6 |
Rep 4,936
and v10's and v12's their convenient for all engines take the sl600 or veryron both are v12's ( two v12's for the veyrons) twin turbo.
[SIGPIC][/SIGPIC]
05-24-2010, 07:07 PM | #7 |
Rep 363
The Veyron's engine is 2 Audi Twin Turbo V8 engines put together in "W" configuration. Not "2 V12s" as you said. So it's a W16 Quad Turbo.
IMHO I believe TT is better but not always possible. So single at times is better and can make more power but not through out the rpm range like TT can |
05-24-2010, 07:18 PM | #8 | |
Rep 1,629
In theory, one snail should be more efficient than two. For the same volume of air, it should be possible to have less total mass on the turbine and compressor wheels of a single turbo than on a comparable twin turbo setup. The primary advantage to having a twin turbo setup is that you can have shorter exhaust mains and thus reduce enthalpy loss.
Cars>Women
05-24-2010, 09:40 PM | #9 |
Modder Raider
759
Rep 8,633
Drives: M3
I think it all comes down to lag and power.
The bigger the turbo the bigger the lag and the bigger the power. The smaller the turbo, the smaller the lag but the smaller the power. Put 2 turbos togehter with different sizes, you have just increased the power and decreased the lag.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
05-24-2010, 10:19 PM | #10 | |
Modder Raider
759
Rep 8,633
Drives: M3
I guess we'll see though soon.
05-25-2010, 12:13 AM | #11 | |
Rep 739
And the main advantage of the twin scroll set up is in its much improved transient response over open scroll. Yes, the lag is reduced also, but the difference in response is night and day.
03 Golf TDI w/ r32 conversion - 120bph/40mpg ftw for now..
06 Evo IX MR - 500whp,,,sold..... |
05-25-2010, 05:04 AM | #12 |
Rep 549
I'm guessing twin turbo should have advantages, since BMW actually did put that in the N54. If there were no gains in that approach they probably would have gone the easy route from day 1, ST.
05-25-2010, 09:03 AM | #13 | |
Rep 2,822
Drives: X5M F85
05-26-2010, 09:51 AM | #14 |
Rep 739
Really? I don't care if you're the head engineer of the BW or garrett. You can't completely eliminate lag.
05-27-2010, 11:06 AM | #15 |
Rep 621
Single Turbo FTW if you're going big. Its more efficient to run one large turbo off all 6 cylinders if you want real big power. That's why most all twin turbo supra owners switch to single
05-27-2010, 12:55 PM | #16 |
Rep 739
Agreed...if you're referring to the twin turbo comment.
05-29-2010, 02:51 AM | #17 |
Rep 621
05-29-2010, 10:31 AM | #18 | |
Rep 739
Large single turbo is more efficient than STOCK twins mainly because of higher compressor efficiency and reduced turbine backpressure. Aftermarket twin turbos can also make big power due to this reason. Most supra owners go to big single because of its simplicity and reduced cost, not because single is superior to twin turbo set up. The opposite can be said in other applications where twin turbo set up is favored over the single such as large displacement V motors.
05-29-2010, 10:45 AM | #19 | |
Rep 363
Old for a reply but had to because I know I'm right...thanks for providing a link that does not bck up your statement...all it saidis that it was talking about "W" shaped engine eg: W8 engine= 2 VR4 engines at a 72 degree angle. Now you may have been right about VW producing the engine but VW and Audi are in the same boat. The reason the W8 is called that is because it is 2 V4s(VR4) so V+V=VV or W...but you are saying the Veyron uses 2 W8s so if my math is correct... (V+V)x2=(V+V)+(V+V)=W+W=WW= Zigzag |
05-29-2010, 10:54 AM | #20 | |
Rep 363
Now people might go against me on this but it's true...nothing is instanteneous that involves more than 1 moving part and even with one moving part it has to be inflexible. Now if you want to start getting into really instantaneous then we can get into quantum mechanics but I won't go there. Sorry everyone just woke up and in a bit of an argumentative mood today. |
05-29-2010, 11:44 AM | #21 | |
Rep 621
05-29-2010, 11:50 AM | #22 |
Rep 1,917
simply put, 2 is almost always better than 1. But single turbos are often preferred for price and space considerations. If you could have a engine that was truly bulletproof and had the room, 2 turbos would be advantageous.
