Good read on CAN data collection, methods and possibilities
05-25-2010, 01:41 PM | #1 |
once Treppiede
63
Rep 915
Quick read
Original study (PDF) by AutoSec I am still reading the PDF... but man, I wish I had more time to tinker with this! Enjoy, -Walter
2013 E92 M3 | 6MT | AlpWhite | SilverNovillo | CarbonTrim | ZCP | PremiumPkg | Alarm
2009 E92 335i | 6MT | AlpWhite | CoralRed | AlumTrim | M-Sport | Nav | Logic7 | Alarm (sold to a friend - still in the family) |
05-25-2010, 01:53 PM | #2 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
I think there are multiple CAN's in the car. I believe Vishnu access a certain area and sniffs those packets.
I would like a complete tune in the future to completely operate everything from, A/C, lights, dash, traction, etc..
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
05-25-2010, 03:12 PM | #4 | |
The Stig
31
Rep 1,232
And yes there are multiple BUSes, most of which are CAN-based. But still, WTF to that last sentence. I'm hoping you forgot a
05-25-2010, 03:16 PM | #5 |
Rep 2,663
A know a guy that controls each head light on his VW. He can have one go up 15 degrees and the other one down 25 degree, independently. It has nothing to do with making the car faster but he can customize his entire car.
05-25-2010, 03:17 PM | #6 |
Rep 2,663
Different settings for different driving styles.
05-25-2010, 03:18 PM | #7 | |
The Stig
31
Rep 1,232
Are you smoking crack? Like, a lot of it?
05-25-2010, 03:23 PM | #10 |
Rep 2,663
Is not his engine tune, but he has a computer system that controls a lot of the settings in the car. What I'm referring to is to have a tune incorporate a lot of these features in one.
05-25-2010, 03:24 PM | #11 |
The Stig
31
Rep 1,232
And to try and salvage some of this trainwreck, the article is a lot of FUD....yes a lot of this can be hacked if someone really wanted to tap your CANbus, find out what commands were required to even talk to the right module, then wire up a laptop and 3g connection to do this all remotely. It would be a hell of a lot easier to just cut your brake lines, and probably more effective too.
05-25-2010, 03:24 PM | #12 |
Rep 2,663
I must not be thinking right right now. I'm up on 1 hr sleep.
05-25-2010, 03:26 PM | #14 |
Rep 2,663
I also don't think you can manually cut the breaks electronically if someone would physically press the brake pedal. Doesn't the brake pedal overrides the electronics?
05-25-2010, 03:27 PM | #15 |
The Stig
31
Rep 1,232
I don't know what this says.
05-25-2010, 03:31 PM | #16 |
Rep 2,663
If you tapped into my CAN and controlled the brakes remotely to not have my brakes work, I can stop the car physically with the brake pedal.
05-25-2010, 03:33 PM | #17 | |
The Stig
31
Rep 1,232
In other words, anything is possible, but it's not worth the time.
05-25-2010, 03:35 PM | #18 |
Mad Linux Guru On The Loose
1131
Rep 5,404
Welcome to like 5 years ago!
05-25-2010, 03:36 PM | #20 |
The Stig
31
Rep 1,232
I agree. I'm actually somewhat disappointed in myself for giving a serious answer to the above question...
05-25-2010, 03:37 PM | #21 |
Rep 2,663
Ok, I'm going to sleep. My brain is on overload.
That's what I thought too on the brakes which was mentioned in the article.
05-25-2010, 03:50 PM | #22 |
once Treppiede
63
Rep 915
The 'hackers can disable your brakes" part of the article is irrelevant BS, typical journalistic title. What I found interesting was reading about CarShark and skimming through the PDF... which I am still trying to read between one thing and another here @ work.
-Walter
