Cruise control issue with JB3
05-27-2010, 01:33 PM | #1 |
Rep 1,857
Whenever I'm using cruise control and accelerate with the second position on the stalk, my car goes into limp mode. Does anyone else have this problem?
I'm on the latest firmware.
05-27-2010, 09:20 PM | #4 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
06-05-2010, 10:14 AM | #9 |
Rep 2,978
I just got my JB3 installed. What exactly is this problem? If you use the cruise control, it'll throw a CEL? And does this only happen when you try to increase/decrease the speed using the up/down feature? Will the CEL go away after turning the car off then on?
06-05-2010, 10:28 AM | #10 | |
Joint Chiefs of Staff
4927
Rep 116,037
Known bugs: 1) When using WOT X-axis view fuel pressure and map don't chart properly. 2) When using cruise control acceleration, if you double click to accelerate more than 1mph at a time you may recreate a misfire. Apparently this bug has been around since 1.4 but has only been reported by 3-4 users. We'll look in to it soon. None of my customers have ever had an issue with it but a few must have reported it to BMS for it to become a known bug item. According to the notes it comes up when you accelerate 5-10mph using the stalk. Misfire would be an SES light. Mike |
06-05-2010, 10:36 AM | #11 |
Rep 2,978
Ah ok. So, it only happens when you speed up by 5-10 mph (for some cars).
I'd like to try this, but if the SES comes on because of this, do I need to have the BT scanner to clear the code or go to the dealer? |
06-05-2010, 11:38 AM | #12 | |
4927
Rep 116,037
Mike |
06-05-2010, 11:39 AM | #13 |
829
Rep 3,982
I have never had this problem on any of my 335i BMWs. But I only click 1mph increments on the stalk. I will try the 5mph increments. What speeds does this occur at? Normal 65mph highway speeds? Speeding up only, or slowing down also?
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
06-05-2010, 08:02 PM | #15 |
Rep 70
I noticed the known error expressed on the Sticky but I forgot and tapped it anyway. No big deal just went to a more agressive pull then it hit reduced power/ tripped light.
Cut the car off and fired her back up and the light and reduced power was gone no biggie!! Won't forget again!!
JB4w/BEF/AlpinaTransFlash/DCI/CPw/BOV/CGMS Meth/3.5bar TMAP/BT Intercooler/Silicone Inlets/Al Outlets/RB External PCV w/2 OCCs/Plugged Heads/Index 12s/3''DPs/Electric Cutouts/MFactory LSD/Coilovers/Spacers/LUX Angels/Android CCC Upgrade/19''M405s 235/275/Wrapped Matte White
06-06-2010, 09:40 AM | #16 |
Rep 101
Pull or press the stalk a little further and you'll notice a little step. If you pull reallynhard on the stalk, the E90 can brake very hard relying only on your finger!
2010 335i X-Drive: Black Sapphire, M-Tech package, Navigation, Steptronic, JB+, BMS DCI, H&R Sport springs, Bilstein shocks,TMS brake kit, TMS boost gauge, matte black kidney grille, Bimmian painted reflectors, Bimmian smoked LED side markers, shadow black "335xi" badge, iPod interface, OEM roof rack & bicycle mounts, 19" LC818 (f 8.5, r 10)-- 12.768 @ 108.88
06-06-2010, 05:11 PM | #17 |
Former E46Fanatic
13
Rep 284
I don't go into limp mode but I do have a cruise control issue.
Instead of limp mode I get a cruise control error and cruise will not work again until i restart the car.... |
06-20-2010, 04:54 PM | #18 |
LSD - No, you're not seeing things
72
Rep 3,302
Interesting.
I cannot create the 5mph error, BUT when I tap the resume button and Im not near the target speed, it misfires so badly so I have to take it off. If its just a few mph under it picks up and holds cruise just fine. This is at normal running and about 2k rpm so its not labouring at tickover speeds or anything like that. Anyone else? |
06-23-2010, 08:54 PM | #19 |
4927
Rep 116,037
A little good news guys, BMS solved cruise control bug where you might get a misfire if you used the cruise control stick double click to accelerate 5mph or more. The fix is in the 6/15 alpha firmware and is posted on their site.
Mike |
07-05-2010, 05:23 PM | #20 |
Rep 292
Cruise Control
I've had the same problem with my new JB3. I was on the freeway and put on my cruise control. I threw an engine malfunction light and my service engine soon light came on. My cruise control doesn't even work anymore. After restarting my car, the engine malfunction light went away, but the service engine soon light is still there.
07-05-2010, 05:44 PM | #21 | |
4927
Rep 116,037
Mike |
