Intro/ JB3 Dyno Runs
06-02-2010, 09:45 PM | #1 |
Rep 36
Sup everyone,
I finally found time to post some charts of my recent dyno runs, hoping to get some feedback or suggestions on areas of improvement from you guys. It's been almost two months since i purchased my 335 (from an 08" G35) and i'm loving it so far. I decided to tackle the performance department first before anything else and started reading up on different ECU tunes. Juicebox was definitely my top choice one for the money, the positive feedback from current user, amazing gains and last Terry is always willing to lay a helping hand with any questions you may have (not sayin other tuners don't do the same). With that said i went ahead and purchased their DCI,JB3,BT package, few weeks after purchased ETS intercooler as well (Great product). My current goals as of now is to break 450whp / 11s 1/4 mile. During the course of this project i will be documenting and posting real life dynojet numbers as i go along. Here are my current dyno charts as of now, please let me know what you guys think. Here is pic of my pervious car Stock baseline w/DCI after 2 previous runs (heat soak) Map 5 JB3,Intake,93 (best run) Map 5 First pull IC,Intake,JB3,93. (nice TQ but no HP gain) Map 5 Second pull IC,Intake,JB,93 (notice power loss) Map 5 Third pull IC,Intake,JB3,93 (big power loss) After this point i decided to crank up the map setting. Right away on the first pull we notice an increase in HP so decided to let the car cool off before making a second pass on the new map. I was only able to get two WOT passes on the new map due to dyno time. Map 7 First pull IC,Intake,JB3,93 (1st WOT run) Map 7 Second pull IC,Intake,JB3,93 (2nd WOT run) |
06-02-2010, 09:49 PM | #2 |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
That second map7 run looks allot better and cleaner.. nice power under the curve. What dyno shop did you use? How much if you don't mind me asking.. been looking to dyno my car lately...
Awesome! Get some DPs and Meth.. 400s easy
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
06-02-2010, 10:03 PM | #4 |
Rep 36
Thanks! Twilight performance located in Ali Baba Opa Locka. Rates vary but i believe its about $35 for 2-3 pulls not bad considering most shops charge $65-80.
06-02-2010, 10:05 PM | #5 |
Rep 36
06-02-2010, 10:53 PM | #6 |
Rep 1,145
Were the runs with the FMIC on a different day from the JB3/DCI? If that's the case, heat soaking after 1 run seems odd.
Might want to also document the temperature, humidity, etc. during the runs. Might explain the difference in numbers. |
06-02-2010, 11:12 PM | #8 |
Rep 1,065
Drives: RB PWRED E90 N54 6MT
That is a great price.
RB Turbo/Procede V5/Vishnu PWM Meth Injection Kit/Vishnu DCI/AR Catless DP/AE Performance Exhaust(Sold)/Helix FMIC/Forge DVs/Rixster Vent Boost Gauge/Wavetrac LSD/KW V3/ACT Street Clutch Kit
06-02-2010, 11:29 PM | #9 |
Rep 36
Yes they were done a few weeks after the JB3/intake run. Can't seem to explain why just such as drastic power loss after each pull on Map 5. Maybe a mixture of boost drop, more air flow and richer A/F.
06-02-2010, 11:43 PM | #10 |
Rep 36
Just a regular electric fan by the radiator/intercooler nothing big. All the FMIC runs except for the second run on Map 7 were done back to back. Last runs we allowed about 30 mins cool down period.
06-03-2010, 06:52 AM | #12 |
Rep 36
I'm confident that with a couple more WOT pulls so the new map could adapt and a bit more leaner A/F i'll get to 360hp but it's no big deal right now still have a road of performance mods still ahead.
06-03-2010, 07:06 AM | #13 |
Rep 5,175
Leaner/richer doesn't produce the same power on a DI car. Now adapting to octane is real.
06-03-2010, 09:08 AM | #14 | |
Rep 4,633
Try to get a better fan setup, carpet drying fans usualy work good towards the IC.. you want another fan towards the DCI and another one towards the radiator of the car. 3 main points to cool and make more power. You will actually be surprised what cooling periods between each run and having good fans will do for power, i have seen 20WHP gains from just getting extra fans at a dyno. If you really want to cool even more get another fan towads the oil cooler |
06-03-2010, 05:04 PM | #15 | |
Rep 36
06-03-2010, 05:19 PM | #16 |
Rep 1,973
Meth!
06-03-2010, 05:29 PM | #17 |
Rep 6,631
If you look at the power >6000, you have a lot of power gained up top compared to your stock FMIC runs. This is the ETS FMIC, correct?
To join the 400whp club, time for some meth and downpipes. Throw in some race gas for good measure, crank the boost and you'll be loving your numbers!
E90 LCI N54 6AT
06-03-2010, 08:23 PM | #18 |
Rep 36
Yes ETS FMIC, great product BWT!!
Looking into full exhaust and downpipe now but haven't decided what brand to choose from. Downpipes i'm thinking either Macht Schnell or AR Design but as for exhaust, i really really dont know. Since i plan on spraying nitrous, i'll rather leave meth out the picture for now but let's see what happens. |
06-03-2010, 09:02 PM | #19 | |
Rep 4,633
I give my car 20 min cool downs between each run, make sure my DCI or intake is getting DIRECT independent air to it, and the FMIC is getting a carpet fan as you were. Next time on the dyno make sure to get a carpet fan to the DCI, FMIC as you did, and one either to the radiator if you can. |
06-04-2010, 05:03 AM | #21 | |
Rep 5,175
06-04-2010, 05:04 AM | #22 | |
Rep 5,175
