New CP-e Downpipes!!
06-28-2010, 08:12 AM | #1 |
Rep 45
ive just ordered some CP-e Downpipes has ayone else used these pipes yet?? i havent ordered the Dp fix yet? will the car run ok without the fix? is it just a light that comes up or does it give u the reduce power sign or anything, i was also wondering will i need it remapped after or will it run with the map i have at the moment. im runing a custom map at 358hp??
06-28-2010, 11:06 AM | #2 |
Rep 340
I have the Cpe dp's. the fit and finish are the best I've seen. you will definately get a light if you don't have an O2 sim of some sort though. As far as performance changes go if the car has a SES light I'm not sure about. what type of tune are you running?
06-28-2010, 12:01 PM | #3 |
Rep 45
hi there, my friend remapped it for cheap as he works for a tuning company, i had it dyno'd at 360hp and 400+torq, since then i have installed a BMS DCI and supersprint decat pipe (removin secondry CATS). I have ordered a DP fix today as i wasnt sure, should i wait for that to be delivered before fitting the DP's, or can i do the DP fix after?? thanks for ur help m8.
06-28-2010, 06:10 PM | #4 |
My X5d tows my spec miata to the track.
74
Rep 1,254
You'll get an ses light but it won't affect performance. The noise will go up a little but that's a small penalty compared to the noticeably faster spool. Enjoy. Fitment is perfect.
