335d Gearbox oil, to change or not to....
06-29-2010, 07:00 AM | #1 |
Rep 939
Hi All,
My car is a 56reg 335d with 70k on the clock. Its due a service in a few months and I wondered what your opinions are on getting the gearbox oil changed. I've had the car remapped from 63k and I do plan to keep the car for about another 4 years (as I love it!) Am I been too cautious? theres nothing in the manual about gearbox oil service intervals, my guess would be that the inspection services do carry out some tests on the gearbox oil and only change it when it meets some criteria. Is there some sort of performance oil that would be just generally better? If anyone has had this done, how much would it cost from a BMW indy? Thanks |
06-29-2010, 07:09 AM | #2 | |
Rep 13,043
Drives: BMW M340I G20
The oil from BMW is about £18+ vat a litre and you need about 10 litres, plus a filter. Whoever does it make sure they change the torque converter oil as part of the quote. |
06-29-2010, 07:16 AM | #3 |
Rep 497
i was under the impression that all auto 'box's needed the gearbox oil changed at a set interval or mileage. i know my missus DSG is due one at 3/4 yrs, dont remember which exactly. and my dads honda was due one a 4 years. i know the honda DCT's had a technical bulletin due to a batch of them used a lower quality gearbox oil initially and that messed up the gearbox. honda did the right thing and extended the gearbox warrenty to 7 years/100k miles. and my dads whole auto transmission got replaced under honda warrenty!
so that'll be something i'll be keeping my eye on. will be good to know if there is a schedule and where it is. would have thought it would be in the service book or something |
06-29-2010, 07:20 AM | #4 |
The Tarmac Terrorist
958
Rep 29,345
Drives: 997.2 GT3
There a sealed unit which does not need an oil change.
Not a bad idea though if your keeping the car long term if you can justify the cost.
997.2 GT3
06-29-2010, 07:31 AM | #5 |
Rep 8,972
Like carlos says, it's meant to be 'sealed for life'. How long 'life' is though i'm not sure!
Often with sealed unit diffs and 'boxes there won't even be a drain plug, you may need to loosen off and crack the gasket on a housing plate or something to get the oil out. Not sure on the bimmers though... |
06-29-2010, 07:37 AM | #6 |
Rep 13,043
I think there is something odd about the filter, like it's part of the lower pan and fooking expensive, so washing out might be an option.
06-29-2010, 08:31 AM | #7 | |
Rep 939
Excuse me wanting to know 100%, just if your correct then I'd expect a lifetime product to last 10 years (according to trading standards etc). If thats the case then I'm happy to keep my money and put in a 2nd hand gearbox if mine should blow in several years time (alber it shouldn't as its a life time oil'd box) Thanks |
06-29-2010, 08:37 AM | #8 |
Rep 9,915
Drives: VW T5
Why not contact the gearbox manufacturers direct for their view...
http://www.zf.com/eu/content/en/grea.../homepage.html
06-29-2010, 08:42 AM | #9 |
Rep 2,834
I'm pretty sure that the official BMW line is that the boxes are sealed units.
BUT... I read a post on Piston Heads a while back about some dude who had a 5er or something with gearbox problems. He drove his motor to Germany to get a ZF (they're the guys that make our boxes) workshop change his oil for him. I will see if I can dig out the link...Piston Heads search is wank though. Google FTW: http://www.pistonheads.com/Gassing/t...oil%20changed? |
06-29-2010, 09:02 AM | #10 |
Rep 5,493
OP - please make sure you post in the correct sections. This thread has been moved accordingly.
BMW gearboxes are theoretically sealed for life. By life I think the rough estimate is around 150,000 miles or so. However, that doesn't mean you can't change the oil if you want to. It's actually a very easy process and is similar to changing the engine oil. The only difference is that instead of replacing the gearbox oil filter on its own, you have to replace the entire gearbox sump pan because the filtration is built into it as is the gasket. It's not an expensive item by any means. Changing the gearbox oil is probably a worthwhile thing to do if the car has had a harder than normal life. I changed the oil on mine about 3000 miles ago - the oil that came out was pretty much contaminant free although it had a bit of discolouration as you would expect. Fresh oil installed, new pan, and there's not a noticeable difference to be honest. Mentally you'd know there is a difference, potentially, but in practice the gearbox was never less than smooth anyway. And you definitely don't need to go to ZF to change the oil - I did mine at Birds on the ramp and it took about an hour and a half...
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
06-29-2010, 09:40 AM | #11 |
Rep 2,834
06-29-2010, 09:58 AM | #12 |
Rep 5,493
06-29-2010, 10:03 AM | #13 |
Rep 13,043
Drop Kevin an email, I'm sure he will be happy to quote.
Email address has been edited out to prevent spambots! www.birdsauto.com |
06-29-2010, 10:51 AM | #14 |
Rep 497
wow, sounds good to me! great info guys
who would have thought, bmw and cost saving motoring...impressive |
06-29-2010, 11:09 AM | #15 | |
Rep 65
I have changed to my previous 530dA gearbox oils after 80000km + flushing. 13 litres oil trought the gearbox and the new filter. Old oil looked extremely dirty and it was also a little bit grey coloured. Gearbox which was on my previous 530dA was made by GM. I need to mention that our weather conditions are little bit different than in UK or in middle europe and ofcourse technically cars on their limits especially in wintertime. Temperture differences can be easily +6 to -25C in one day.
F20 120dA ///M-Sport | M Performance Power Kit
06-29-2010, 12:09 PM | #16 |
Rep 5,493
To do a ZF automatic gearbox oil change properly, you need to flush the oil lines completely. Therefore you would need at least 10 litres of gearbox oil - the correct type of oil is a heavy duty longlife high grade oil like the top-end Fuchs Titan oils. From Opie its around £17 per litre...! Couple of hours labour, and the sump pan (which has the filter and gasket pre-installed) - probably total cost near enough £290 + VAT....
06-30-2010, 08:00 AM | #18 | |
Rep 5,493
The gearbox isn't that big - it doesn't actually take 13 litres of oil. But because you need to do a full flush of the gearbox including the lines, you need quite a bit more oil than just what's in the sump to push the old dirty oil out. It's not good enough just draining the oil out. And you can't flush the system with water!
06-30-2010, 08:05 AM | #19 | |
Rep 13,043
Are you suggesting they fill the box and then dump it out again Tony? |
06-30-2010, 08:47 AM | #20 |
Rep 5,493
Sort of - not exactly filling it twice, more running the new oil through to push out the old, then sealing the unit and filling to capacity
