Power Handling of the 335i
12-21-2006, 09:25 PM | #1 |
Vitamin K
Rep 15
Well guys i would like to introduce myself, my name is Kevin and im from the currently cold as balls state of CT. i have been watching the release of the 35i and im pretty set on turning to the dark side and trading in my is300. im loving the power coming out of this car from just minor upgrades. im a top notch fabricator with countless hours of time under the hood of some of CT fastests hondas and lexus's, supras and the latter.. and cannot wait to get my hands on this new platform. i do have a few questions for those of you already modding, what is the power handling of the 6spd manual tranny/ clutch set up, and whats the block going to take in this thing? i mean am i going to have to rip apart a brand new motor to get the power levels i want? Well, hope all is well in modding and i cannot wait to share my experences with all you in hopes we both learn on this new platform. i plan on taking a ride to BMW once i finish the moving of my business into my new office.
thanks again Kevin. |
12-21-2006, 10:07 PM | #2 |
Vitamin K
Rep 15
no one?
what about LSD? i cannot belive BMW produced a turbo car in the 300hp range with a 1 legger! are their LSD upgrades??
[Admin Notified]
American Capital Services Alpha-Investments company |
12-21-2006, 10:08 PM | #3 | |
Rep 100
The block will go to 497hp. Kidding of course as no one knows at this point. Welcome to the club!
2007 335i Coupe
6-speed manual Space Grey - Coral Leather Sport - Premium |
12-21-2006, 10:25 PM | #4 |
Vitamin K
Rep 15
haha yah i guess its kinda early to tell huh lol. compared to your is350 how does the 335i hold up?
[Admin Notified]
12-21-2006, 10:43 PM | #5 | |
Your resident 4um troll
127
Rep 2,020
12-22-2006, 02:37 AM | #6 |
S0THPAW
8731
Rep 7,847
12-22-2006, 06:56 AM | #8 |
Rep 101
Drives: F07 535 GT
Garage List 1961 HUMBER HAWK [0.00]
1995 M3 [0.00] 1988 sierra sappire ... [0.00] 1978 rangerover [0.00] 1967 Mercedes 200 [0.00] 1967 Unimog s404 [0.00] |
I can tell you the 335i uses the ZF type g transmission, which is the same as in the 650 and M5/M6, It is a very strong 'box. Ask ZF how much torque it can take. The block is probably fairly strong given its modern design, but the high comp. ratio will cause big problems with high boost. Diferent pistons will help, or perhaps the old cylinder head spacer or thick copper gasket will do.
The direct injection is a bit complicated, with up to 3 injections per firing event, but the high maximum fuel system pressure should leave scope for lots of increase in fuel volume. |
12-22-2006, 10:05 AM | #9 | |
S0THPAW
8731
Rep 7,847
12-22-2006, 10:29 AM | #11 | |
Rep 22
I can't seem any reasons why the LSD would screw anything up. If anything, it would cause the system to have to kick in less. |
12-22-2006, 10:35 AM | #12 | |
127
Rep 2,020
12-22-2006, 02:53 PM | #13 |
Rep 122
What do you have in mind for power goals? I do nto think this motor is a Supra motor that will take 650+ WHP. But if you are looking for a solid platform that will make around 400, I think this is the right ride for you.
2016 SO M4
12-22-2006, 04:33 PM | #14 | |
Rep 100
2007 335i Coupe
12-23-2006, 01:47 PM | #15 | |
Vitamin K
Rep 15
id be happy with 475 to 525 and a lsd upgrade
[Admin Notified]
12-24-2006, 09:18 AM | #17 |
Vitamin K
Rep 15
id say based on past exerience turbos this size can sustain 8-10psi each, with a maximum 20psi on tap. i belive with this compression ratio and a nice meth/water injection kit, sub 500 will be within reach. im hopeing that someone will throw out a single upgrade manifold, altho the instant boost is nice, correctly sized dual ball bearing turbos are able to produce the same pressures just as fast with more power potential. as for headers and down pipe, im going to have to wait for the after market industury to put those out cause frankly fabricating those things sucks. first thing im going to do is rip out that plastic tanked intercooler and fab out a custom hard pipe FMIC setup.
[Admin Notified]
12-29-2006, 11:26 PM | #18 | |
Rep 55
Standard-lock clutch LSDs will not cooperate smoothly with the DTC/DSC on. M-car differentials won't fit other BMWs, since they are controlled by the respective ECUs. So they 're not a solution, either. The best solution must be Torsen (torque-sensing) differentials, such as the "automatic torque biasing" ones, designed by Quaife. They 're much more flexible and adaptive. @Robin Hood: What type of LSDiffs does Drexler produce? PS: I want that car (335) very badly, but will not order one, till we solve this problem! If we don't, I guess I 'll have to settle for a used e46 M3! |
12-30-2006, 12:40 AM | #19 |
127
Rep 2,020
yea, dont forget to the dsc can and will apply brakes one at a time, imagine if it needs to correct with only one of the rear wheel, your ass is toast
12-30-2006, 05:31 AM | #20 | |
Rep 101
Drives: F07 535 GT
01-14-2007, 04:30 PM | #21 |
Rep 9
Did you guys try www.diffsonline.com yet?
They/bimmerworld built the rear ends for the 25 hr thunderhill race (335Ds) http://www.caranddriver.com/features...-update-1.html |
01-14-2007, 04:36 PM | #22 | |
Rep 9
The M diffs are NOT ecu controlled. They just dont fit. The rear subframes are usually M specific. Who knows what the new E9x/M3 is going to use. The current M diffs use clutches. there is a viscous sheer pump that increases pressure on the clutches durring slippage. I have a static lock/ramped clutch LSD in my ZHP, and it does not interfere with DSC. The ramped clutch LSDs offer varying lockup like the quaifes, and are proven in the racing industry. The difference is static lock which can be customized. |
