19" style 225 alloys
07-17-2010, 02:51 PM | #1 |
Rep 138
Drives: 2008 E90 320d SE 177
Hi all Im after a bit of advice from you knowlegable folk.
Does anyone know if the 19" style 225 alloys would fit straight on to an 08 e90 320d SE at all? Im running standard 16" at the moment but they just look to small and want something bigger and Ive been offered a set of genuine ones in cracking condition for less than a set of replicas would cost, thanks. Any advice appreciated M |
07-17-2010, 02:56 PM | #2 |
Rep 2,927
Drives: E60 530D M SPORT
yes genuine ones will fit,
07-17-2010, 02:59 PM | #3 |
Rep 138
Thanks for the quck reply wasnt sure if the offsets would be different meaning they wouldnt fit or would stick out or rub etc
Need to find some tyres now next sop camskill I think, cheers. |
07-17-2010, 04:32 PM | #4 |
The Tarmac Terrorist
958
Rep 29,345
Drives: 997.2 GT3
Glad you have found a set in cracking condition. Not
many like that.
997.2 GT3
07-17-2010, 05:17 PM | #6 |
Rep 66
sorry to gate crash
quick question how many bar should the 19's be? just got mine back from dealer after a wheel issue and the front are at 2.6 back at 2.4. door card says 2.8 at back... but why would they put the wrong pressure in? Last edited by baggy; 07-17-2010 at 05:23 PM.. |
07-17-2010, 06:15 PM | #8 |
Rep 626
2.4 at the rear sounds low now matter what tyres you're on. Should be higher than that as if BMW have filled them they always follow the door cards unless they've let the chimp do it.
You haven't got 225m alloys have you. If you have make sure they've not cracked and are letting the pressures drop. |
07-17-2010, 06:16 PM | #9 |
Rep 66
07-17-2010, 06:21 PM | #10 | |
Rep 66
07-17-2010, 06:25 PM | #11 | |
Rep 66
07-17-2010, 07:08 PM | #12 |
Rep 626
If the cars been to BMW for cracking rear alloys and they've given you new ones then they may have dropped the pressures intentionally to help prevent excess stress on the backs and to allow the tyre at least some give instead of putting the majority of the load on the rim.
Dunno, just a thought. |
07-17-2010, 07:16 PM | #13 | |
Rep 66
07-17-2010, 08:42 PM | #14 |
Rep 626
I'm not sure I would in all honesty. As far as I know 225s have an inherent weakness in their build, run them on softly sprung cars with normal tyres and they'll be fine forever an a day. Put them on a stiffly sprung BMW with runflats and they will almost certainly fail at one stage or another.
The only way to be sure of that is to drop the runflats and get normal tyres but if thats not an option I'd leave the pressures as they are if thats what BMW left them at. They must have done that for a reason and although lower pressures will ultimately cause higher inside edge tyre wear it should reduce the likelihood of a rim cracking again. Ring the dealer who did it, ask for the head technician and run it by him and ask his advice if you're not sure. |
07-18-2010, 10:53 AM | #16 |
Rep 29,203
Actually, all OEM e9x wheels, 16" to 19" will fit your car.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
07-18-2010, 11:44 AM | #17 | |
Rep 2,475
Hence it is possible that underinflated tyres are probably the key cause of the cracks with RFTs - this would also explain why it was not picked up during testing of the rims/tyres before they entered series production (as they would have probably been careful with pressures during R&D). |
07-18-2010, 01:28 PM | #18 |
Rep 626
Then if thats the case BMW are crazy fools underinflating the tyres making the problem worse.
I thinka phonecall to the tech manager is in order here for the op. |
07-18-2010, 03:14 PM | #19 |
Rep 138
Guys all this talk of cracked alloys made me do a bit of digging and reading the threads has put me right off the idea now, are the cracks easy to see when the alloys are removed? Any tell tale signs I should look for?
This may be the reason that Im being offered them at such a good price though I know the seller so would hope this isnt the case. |
07-18-2010, 03:17 PM | #20 |
Rep 138
Thanks remmib thats very useful to know, I want bigger alloys on but want to keep quite a stock look but not too stock so Im avoiding the MV3 alloy as they are the normal choice but don't want to go down that route.
07-18-2010, 04:57 PM | #21 | |
Rep 2,475
When I bought my 225s I knew about the cracking - I just made sure they had a factory finish on the inner rim and no cracks before I paid for them. So, as long as you're careful, go for it - they're great looking wheels. Having said that as you have an SE IMO I think you'd be better off with Style 162 or even 158 wheels. |
