I love the extra 50hp & 75ft-lbs!
12-29-2006, 08:02 PM | #1 |
Falling in Love with German Boost
22
Rep 298
Drives: 335i, E350, Accord EX, GSXR750
Garage List 2007 BMW E92 335i [0.00]
2007 Mercedes E350 [0.00] 1994 Honda Accord E ... [3.60] 2006 Suzuki GSX-R 750 [0.00] |
Yesterday afternoon, Shiv installed the Xede and dyno'd my car. Here are some pictures, thanks again Shiv! The car runs great and exceeded my expectations although I should try to avoid ever hearing the exhaust on your car again, it sounds spectacular.
Here is another thread showing the installation, pretty much the same process I witnessed http://www.e90post.com/forums/showthread.php?t=40385 Top Secret Stuff happening back there Shiv sets up his laptop so he can upload the 91 octane map into the Xede On the rollers she goes and gets the A/F meter set up Fans are set up, imagine if those things were turbos going into a car Alright, now the real fun begins! :rocks: Car is strapped in with the harnesses and ready to go! Testing begins!!! This is my first time ever witnessing a live dyno session, and I can only imagine how loud it gets with cars running exhausts or straight pipes Wheels spinning with engine speed near 7000 rpms And finally the results BASELINE RUN 271HP and 282ft-lbs WITH XEDE 324HP and 358ft-lbs! |
12-29-2006, 08:06 PM | #2 |
Rep 469
Nice look car, and as expected nice results with your Xede.
Elmaki
12-29-2006, 08:07 PM | #3 |
184
Rep 1,702
Drives: Audi TTRS, 335is
Impressive dyno results
12-29-2006, 08:10 PM | #4 |
Rep 1,794
Drives: 06' E90 330, 20' F97 X3m
ahhhhh the possibilities! good luck n drive safe ...
LIVE FAST..DRIVE FASTER!! |
12-29-2006, 08:12 PM | #5 |
Rep 5,389
Congrats, man! It will only get better over the next 2 weeks...you're gonna love it!!!!
btw - I know you were an active participant in my 1/4 mi. G-Tech thread, so please if you get a chance, get your Xede-equipped 335i timed for 0-60mph and 1/4 mi.; if not on the track, at least with another G-Tech timer...just to compare notes, of course. Thanks.
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
12-29-2006, 08:26 PM | #7 | |
Your resident 4um troll
127
Rep 2,020
nooo!!! go back and make a back to back recording of stock exauhst vs shivs exaust, im dying to hear a comparison
is that much sporadicness normal? going up down up down? or is that just because of the dyno? |
12-29-2006, 08:30 PM | #8 | |
Rep 9,788
Interesting. So they're basically forcing more air into the car. I wonder if the dyno would show the same result without the fans there. |
12-29-2006, 08:32 PM | #9 | |
127
Rep 2,020
least i think thats what they are for |
12-29-2006, 08:35 PM | #10 | |
Rep 9,788
yeah I realized this right after my last post |
12-29-2006, 08:36 PM | #11 |
Rep 4,578
Wow, I'm getting the itch to get the XEDE.
Current: 2021 ///M3 Competition Isle of Man Green
Ordered: 2024 ///M2 Zandvoort Blue Past: 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i |
12-29-2006, 08:38 PM | #12 | |
127
Rep 2,020
50 hp and 75 tq are really good numbers for 91 octane right? xede is getting more and more tantalizing as things progress was this the selenoidless version? |
12-29-2006, 09:19 PM | #13 |
22
Rep 298
Thanks guys, as expected the dyno results are consistent with all the others on 91 octane and even Shiv was pleased at how each car is basically the same.
sflgator, I won't be able to hit up my local drag strip until March and I don't think any of my friends have a G-Tech on hand. If I get access to one, I'll give it a shot. tekno, the kit I have is the solenoid-less version. With all the plastic covering in place, it looks stock Once you take it off, it still looks stock except that the Xede is tucked away in a seperate compartment with some wires coming out... nothing messing looking at all. I believe my gains are typical for 91 octane (I use Chevron). Comparing my numbers with sflgator's, he produces something around 20 more ft-lbs of torque but his HP was close to mine. Maybe octane has a greater effect on torque than hp??? |
12-29-2006, 09:38 PM | #15 |
22
Rep 298
I'm not 100% certain, but assuming higher octane fuel mass is slightly greater than lower octane, exhaust volume should also increase slightly.
12-29-2006, 09:55 PM | #16 |
127
Rep 2,020
actually id like to know what shiv thinks, since in comparison his 93 otane put out more torque that meens somethings probably going on @ the higher rpms w/ the 93 octane
12-29-2006, 10:12 PM | #18 |
1748
Rep 17,960
Drives: A Lot
2007/335i/coupe-- Glad you like it. It was a pleasure meeting you
As for the fans, they are there to provide cooling to the intercooler and radiator. It's a lot less air than what the car would see on the road but it does serve the purpose as long as you allow for adequate cooldown times between runs. It is not to "force feed" the intake or turbos Sflgator's dyno gains aren't directly comparable the car here because it was tested on a Mustang load bearing dyno, not an intertial style Dynojet. This is a much bigger factor than the difference in octane as each dyno uses a different methodology to measure torque/horsepower. This is why it is only valid to compare dyno results taken from the same dyno. All in all, I suspect sflgator's car to put down 5-10 more whp and 10-15lbft of torque more due to the higher octane fuel (93 vs. 91). Just a guess though... Cheers, shiv PS. The wavey lines in the tuned run was caused by the car oscillating back and forth quickly during the dyno pull. That has more to do with how tightly and straigh the car was strapped down than anything else. This oscillation does not exist on the road whatsoever |
12-29-2006, 10:14 PM | #19 |
Rep 4,098
Drives: F30 328i
awesome review!!! glad to see another version in play without the solenoid.
Glad to see the chevron 91 is working well also.. do u have any plans of mixing a higher octane fuel at any point?
12-29-2006, 10:20 PM | #20 | ||
127
Rep 2,020
and something i noticed, does your license plate say peter pan BMW? that is such a weird name for a bmw dealer |
12-29-2006, 10:36 PM | #21 | |
1748
Rep 17,960
Drives: A Lot
cheers, shiv |
12-29-2006, 11:43 PM | #22 | ||
22
Rep 298
Hey Shiv, hope you'll be able to take a little time off and enjoy the New Year instead of constantly dealing with people like myself who want more power lol
I couldn't resist and had to take the car into mountain twisties for a quick run just now and my lord, I have to once again learn to control the throttle again. I turned off the DTC and DSC and this thing spins its wheels so easily through the corners. The car starts to oversteer really quickly so I had to turn on the DTC just to be safe since it's dark now and the road is cold. Boost comes on strong and unlike the stock 335 which at times you forget its turbocharged, now you never forget it has two snails in it. Quote:
