car won't start after removing jb3 2.0!!!! help!
07-28-2010, 09:12 AM | #1 |
Rep 2,007
i get a dsc malfunction message and malfunction in transmission message.
anyone know what could this be? car started fine 20 minutes before i removed the jb3 thanks for the input. |
07-28-2010, 09:19 AM | #2 |
Rep 6,594
Go re-verify the small sub connectors, they may be reversed and that will cause this behavior. Not sure if JB3 also has a power wire but check that if it does.
07-28-2010, 09:55 AM | #4 |
Rep 1,105
Everyone is going to say this but really check the wiring until you can say you
are 99.9% sure it's right. There are pics of all the stock wiring harness on n54tech.com DIY section. After you're sure the wiring is right I'd scan it for codes and delete any from the previous issue you had and try it again. I'm sure someone else from BMS will chime in but thats about all I could say to do right now. You'll figure it out. Don't stress too much. Also was this a pinout or PNP removal? If it were PNP should be much simpler. Just make sure orientation of subconnectors is correct. The have arrows on them and pin numbers to match up with the larger DME connector. |
07-28-2010, 09:55 AM | #5 |
Rep 859
You almost definitely hooked things up wrong when you took the JB3 harness out. The small connectors are the easiest to get wrong. Make sure you put them all in correctly (the arrow on the connectors should point inward) and in the correct spot in the ECU harness.
2007 335i SG Coupe
2009 128i AW |
07-28-2010, 10:03 AM | #7 |
Rep 8,835
Also make sure the harness is completely seated into the socket. Sometimes it might seem like its in but it really isn't.
07-28-2010, 10:05 AM | #8 |
Modder Raider
759
Rep 8,633
Drives: M3
True.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
07-28-2010, 10:08 AM | #9 |
Rep 5,689
If it is pnp then should be something simple but if it is pin-out take pictures of each side of each harness and email them to terry. I messed up when I put the pin-out in and did the same thing. It turned out that I had pin 7 and 8 as opposed to pin 6 and 7.
Biggest thing is dont stress, it will get fixed soon.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
07-28-2010, 10:19 AM | #10 | |
Rep 2,007
will redo it when i get home. |
07-28-2010, 10:31 AM | #11 |
Joint Chiefs of Staff
4927
Rep 116,037
Definitely recheck the harness as I can guarantee something is backwards/swapped or loose. Common mistake is to swap the grey and black connectors on the small subconnector.
Mike |
07-28-2010, 10:46 AM | #12 |
LED Rules
59
Rep 789
make sure you insert the wires into correct hole. It make look right.. but.. double check and count the it correctly.
LED Pimp...
13 Audi S4... |
07-28-2010, 10:48 AM | #13 |
Rep 859
If you lift the ECU a little bit while you lock it down it will make it seat properly. It is very easy to have it sitting just above the socket since the side of the ECU compartment gets in the way when the ECU is sitting in its normal position.
2007 335i SG Coupe
2009 128i AW |
07-28-2010, 11:10 AM | #14 |
Rep 476
also you may want to try disconnecting and reconnecting the battery after you check over your connections. After I switch chips on my JB3 it wouldn't fire up for anything. I didn't disconnect the harness so I knew that wasn't the problem. However, once I reconnected the battery a second time, it fired right up. Had a few ecu related codes though, including transmission.
