BIMMERPOST Universal Forums Off-Topic Discussions Board PC Gurus Water Cooling Question...
      08-01-2010, 06:24 PM   #1
hl0m4n
hl0m4n's Avatar
Question PC Gurus Water Cooling Question...
i currently have a koolance exos water cooling system. do the 3 fans need to blow air to the radiator or out? currently all 3 fans are drawing air out... i thought it was supposed to draw air in to cool the radiator?
help much appreciated, thanks guys.
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      08-01-2010, 06:31 PM   #2
Nifty
Drives: 2022 AWD M3
If they drew air in, you would be picking up heat from the radiator and dumping it into the case which would almost be like positive feedback (Your case would get warmer and warmer causing your cooling system to work harder and harder). You want to reject that heat outside the case, so it sounds like they are operating properly.
      08-01-2010, 07:49 PM   #3
f=ma
f=ma's Avatar
Drives: E90
The fans need to blow air out through the radiator.
2008 E93 335i
2009 E90 335i
