Alarm system on the 323i
08-04-2010, 12:53 PM | #2 |
Rep 1,300
It more than likely it does not. if you call your dealer and give them your vin number they can confirm that for you.
Brian
Black Sapphire, Black w/Burrwood Trim & Shifter, 162's, Mtec H8 AE's, DS1 HID 6000K |
08-04-2010, 11:16 PM | #4 |
Dreamer
34
Rep 837
08-04-2010, 11:58 PM | #5 |
Rep 6,805
Not standard...
MY07 A22 E90 N52Nxi
08-05-2010, 12:10 AM | #6 |
Bored at work....
893
Rep 5,397
Should it not have that large red "bulb" under the rear view mirror if it has the alarm?
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
08-05-2010, 01:10 AM | #8 |
Rep 1,134
Drives: E90 335i LCI
Alarm's are not standard on all 3 series in Canada. However, you can always try holding the trunk release button for 3 seconds to see if the alarm sounds.
I had to get mine through the "executive package". really pathetic.
I can help with Coding in Vancouver. PM me
08-05-2010, 01:59 AM | #9 |
Bored at work....
893
Rep 5,397
No, our 2011 335xi does not. No alarm on her.
08-05-2010, 07:36 AM | #10 |
Rep 6,805
The LCIs doesn't even have the clown nose on the mirror, or the prewire for it.
The Pre-LCI, as far as I know, has pre-wire, so you can get the alarm, install it yourself (if you are capable) and get the dealer to program it if you really want it.
MY07 A22 E90 N52Nxi
08-05-2010, 07:39 AM | #11 |
Rep 608
I have an LCI and I have alarm and clown nose on my mirror. That alarm is pretty loud
08-05-2010, 07:52 AM | #12 |
Rep 61
having a brand new 2007 BMW 323i with no alarm is just really stupid, I also do have the little red bulb looking thing on the bottom of my rear view mirror but it does not flash, it's just there. I thought all BMW's come with alarm.. I guess not.
I will have to purchase one of my own than.
08-05-2010, 11:42 AM | #13 |
Enthusiast
194
Rep 1,282
Drives: 2015 F80 M3
Garage List 2011 BMW E93 M3 [0.00]
2004 BMW M3 [9.50] 2015 BMW F80 M3 [0.00] 1997 BMW 840CI [9.50] 2011 BMW X5 M [10.00] 2008 BMW 335i Conve ... [8.40] |
It's an easy install.
I can help you if you end up buying the system from Tischer. However you will still require the alarm to be programmed at the dealer.
2017 Porsche 718 Boxster Carerra White / Garnet Red / Black
2013 Porsche 991.1 911 Carrera S Platinum Silver Metallic / Black and Yellow accents 2014 F31 328i xDrive Alpine White / Black |
08-05-2010, 12:45 PM | #14 |
Rep 61
I will look into this for sure, how much will you charge to install it?
08-05-2010, 01:01 PM | #15 |
Enthusiast
194
Rep 1,282
Drives: 2015 F80 M3
08-05-2010, 01:16 PM | #16 |
Rep 61
Thanks man, I will PM you once I have it.
08-05-2010, 01:17 PM | #17 |
Rep 61
so the red circle under the rear view mirror is just for showcase so it LOOKS like you have an alarm system but you don't. WOW
08-05-2010, 01:24 PM | #18 | |
Rep 286
The word around the forum is that cars built prior to 3/09 are prewired... But my 1/09 production car isn't! No prewire or clown nose. BTw, the easiest way to check if you are prewired, is to look under the hood for the hood switch connector, or pull down the plastic cover on your roof liner behind the sunroof and look for the ultasonic sensor connector. Check out the alarm DIY page for the official BMW instructions pdf and photos of where to check the above items.
Past: 2009 328i 6MT Alpine white + Oyster
Present: 2017 340i 6MT Estoril blue + Oyster Last edited by Rampage9; 08-05-2010 at 01:29 PM.. Reason: Added prewire check items |
08-05-2010, 01:26 PM | #19 | |
Enthusiast
194
Rep 1,282
Drives: 2015 F80 M3
I have no idea why BMW didn't finish putting the alarm system in, I mean for the extra few bucks and piece of mind it would give all owns I think it's more then worth it and why would they pre-wire the car for it as well. |
08-05-2010, 01:44 PM | #20 | |
Rep 61
