Meth/CMGS Setup Help!
08-07-2010, 09:19 AM | #1 |
Rep 348
Hey guys,
Ok so I got everything setup and I thought ready to go on my meth kit. I have the progressive kit with the cmgs. Anyways I setup the cmgs with 1-10 the same default setting and changed 11-002 12-12 13-17 14-150 I have the version 1.06 cmgs gauge so it is a little different then the 1.07 on where the parameters go. Anyways when I was driving I couldnt get the pump/cmgs to kick the meth on expect one time when I was driving balls to the wall and for a few secs at the top of one of the gears it kicked on. I am guessing I have something set wrong or in the wrong place and it is causing it to wait to long to kick on. What do I need to do? Thanks |
08-07-2010, 09:49 AM | #3 |
Rep 1,311
The settings are fine. Do you have a checkvalve? If so you may need to bleed the system the first time by disconnecting the hose into the checkvalve, make a short burst with meth, and then reconnect it. Be careful though not to blow meth in a hot engine bay... Use a small bottle or something to collect the meth.
