Axle / Half Shaft Upgrades **Info Needed**
08-12-2010, 11:06 AM | #1 |
Rep 5,175
I am in the process of trying to find out more info on some upgrades to our half shafts since there are quite a few that have broken. I am looking for the measurements of the outer diameter of the cage and the window size (where the ball goes). This will make the process easier, then I can get the work done on my shafts and DIY the project for the forum. It shouldn't be a tough job to swap the axles, so I think many can do this in the garage.
08-12-2010, 11:33 AM | #2 |
Rep 1,922
Drives: 2021 G80 M3
thanks for the contribution. I'm waiting for your DIY cause I can learn a great deal with DIYs.
08-13-2010, 07:45 AM | #4 |
Rep 565
I will get to my set on Saturday next week if you can wait. Using the beefier M3 shafts now.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
08-13-2010, 08:00 AM | #5 |
Rep 5,175
08-13-2010, 09:31 AM | #7 |
Rep 5,175
Definitely do not. This is a universal CV on the inside simply being held on by (6) M10 torx bolts. The outside is held on by one M27 collar nut. The axle is then simply pushed through the hub. The BMW special tool is basically a clamp that attaches to the bolts on your hub and it "pushes" the axle through the hub. I suspect any axle removal tool will work. I think I could swap them in under 1 hour per side depending on exhaust removal.
08-13-2010, 09:37 AM | #8 |
Vishnu Powered
69
Rep 2,205
You could also use an impact hammer to knock the axle out of the hub as well. This is what we used when installing the DP's in my XI.
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3 |
08-13-2010, 09:52 AM | #9 | |
Team Zissou
3084
Rep 10,198
08-13-2010, 10:12 AM | #10 |
Rep 5,175
08-13-2010, 11:06 AM | #12 |
Rep 3,261
have u considered sending one of your broken axles to a driveshaft company like the driveshaft shop? most of those companies can remanufacture axles and make them stronger without any special details or prices...
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
08-14-2010, 10:56 AM | #13 |
Rep 565
I am just popping past the workshop. Will ask my tech if he is willing to take it appart and get back to you.
09 C63 |
08-16-2010, 05:46 AM | #14 |
Rep 5,175
08-17-2010, 11:33 PM | #15 |
310
Rep 15,745
I wish I woulda known this when I was pulling Dans axles out and rebuilding them (ultimateendz). I had the joints apart and would have measured them for you.
08-18-2010, 05:17 AM | #16 |
Rep 565
I asked and they ohhhed and ahhed to don't rely on my. Sorry.
09 C63 |
08-18-2010, 05:29 AM | #17 |
Rep 5,175
08-18-2010, 05:29 AM | #18 |
Rep 5,876
How much would a job like that cost? Wondering if I could get a pair and send them down to you for a rebuild to strengthen them (did you just rebuild or use stronger materials)?
08-18-2010, 05:55 AM | #19 |
Rep 5,175
08-18-2010, 06:05 AM | #21 |
Rep 5,175
08-19-2010, 05:25 PM | #22 |
Rep 5,175
Ok, with so many snapping half shafts/axles I got what is needed and we will be moving forward. This will be a full upgrade to the race, cage, and bar on our axle to handle a lot of horsepower. I will write a full review on the parts and DIY the project as always for the forum.
