Mechanic said not to worry...
08-12-2010, 01:05 PM | #1 |
Rep 1,000
I know this topic is overkill but I plan on taking my car to the dealer for HPFP replacement. This is my first service ever with 14k. I have a JB3 and DCI in it. My mechanic who fixed are cars in the past said not to worry about BWM voiding my warantee for that. They would need to prove it blah blah blah and that would be to hard. I just dont have the time to remove the mods. The Jb3 is not a PnP. Any advice??
08-12-2010, 01:17 PM | #2 |
Rep 3,161
TAKE OUT THE JB3!!! it only takes 30min to an hour and while your car is getting serviced, order a PNP harness.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
08-12-2010, 01:19 PM | #3 |
Rep 859
+1. There have been tons of people on here that have been told by their mechanic or SA that it will be okay to leave it in only to have their engine warranty voided after they bring it in.
2007 335i SG Coupe
2009 128i AW |
08-12-2010, 01:23 PM | #4 |
Rep 25
Best thing is to remove them all. Make time. At the very least replace the dci with the stock airbox and drop back down to map 0. Seen too many threads where a mechanic friend says not to worry, and a BMW rep happens to be there a voids the warranty.
08-12-2010, 01:59 PM | #6 |
Rep 1,748
Of Course The Mechanic Said Not To Worry.
If your warranty is voided, its no skin off his back, or money out of his pocket.. Take it out, order the PNP harness and call it a day
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
08-12-2010, 02:08 PM | #7 |
Rep 1,000
When in doubt take it out....that is good. I will make time. You guys are right. I will leave it out for a while and see how long the new fuel pump last.
08-12-2010, 03:00 PM | #8 |
Rep 911
Or ask the mechanic to take it out. At the end it's about the codes on the dme.
(Of course only when your SA and mechanic are "fan" of you) when doubting about them, take it out yourself... Did you check for dme codes? That's even more important then having your tune in...
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
08-12-2010, 03:39 PM | #9 |
Rep 3,004
HA! he wants your warranty to be voided so you can go to him for for service....ALWAYS TAKE IT OUT...."that's what she said" ....wow is it Friday yet?
08-12-2010, 04:39 PM | #10 |
Rep 61
Drives: 2007 BMW 335i Sedan
I have had my car serviced with the DCI in with no issues. But, the JB3, I definitely took out. Heck, I came close to having my warranty voided, but they could not prove that I had a device installed, other than wires had been moved around. JB3 PnP has not flagged any codes for me, and I run Map 5 on it.
2007 BMW 335i Sedan - Titanium Silver - BMS DUal Cone Intake - JB4 PnP Map 7 - ETS Intercooler = BSH Competition Oil Catch Can - STETT CP w/ DV - Macht Schnell 3" Stainless Catless Track Downpipes - BMS Downpipe Fix v3 - V1 Hardwired - SWS Subs w/Alpine Amp
//Coming Soon: Borla Aggressive Cat Back Exhaust - - FULL VC-2 Meth Injec Kit - AR Design Stage 1 Oil Cooler |
08-12-2010, 08:22 PM | #12 |
Rep 1,134
Drives: E90 335i LCI
very useful quote which can be applied to various situations in life as well
I can help with Coding in Vancouver. PM me
08-12-2010, 10:47 PM | #13 |
Rep 1,262
Obviously not ALL dealers are "mod friendly," but I've taken my car in with ALL of my current mods on without any issues whatsoever. Once for an oil change and some other little stuff unrelated to the engine (with time trial #s on the rear 1/4 windows!) and once for an HPFP replacement.
*IF* the dealer is willing to play fair and call you if there's any reason that they could run in to trouble with the replacement, then go for it! Just be sure to set the JB3 to Map 0 - then it'll be completely transparent to their scanner and any programming will go down without a hitch.
08-13-2010, 12:05 PM | #16 |
Rep 946
He probably doesn't have a BT tool to clear the possible tuner codes in the ecu...
08-13-2010, 12:11 PM | #17 |
3442
Rep 79,211
Take it out.... once u remove it and put it back in once, you will understand it even more. ITs pretty straight forward, just follow directions.
08-13-2010, 02:16 PM | #18 |
Rep 239
i just got a new fuel pump w/ my bolt on's left in (dci, exhaust, fmic). i go to two different dealers. one who's closer to me but not "mod-friendly," i've gone for maintenances and brake services. that dealership told me to remove all mods if i want to get my fuel pump fixed. then i go to a farther but more mod friendly dealer and got my software upgrade and my fuel pump replaced w/out a problem.
i would say removing the tune is a MUST (that was the first thing the "mod-friendly" dealershp asked me, if i had a tune or not). then call the dealership and ask your SA if it's OK to bring the car in w/ your bolt-ons. oh yeah checking your codes before you bring it in is a MUST also. hope this helps. it's always a dilemma i know |
