Boost control valve / solenoid
08-13-2010, 02:30 PM | #1 |
Rep 755
Anyone know much about these on our 335i's??
Spoke to Rob at DMS today and will be taking my car down to southhampton so he can diagnose my reoccurring fault. He thinks the reason my car runs great after the adaptations have been reset but then within a few hundred miles starts to drop of a little in performance is that I may have a boost issue that the ecu picks up on and subsquently alters the boost. The reason the adaptations make the car feel stronger inicially is that it takes the ECU a little time to pick the leak or what ever it is then backing things off. Anyway he's advised that I replace the boost control valves or solanionds (not sure what there called) before I make the trip down to eliminate them as a cause. Anyone know much about these or how much they cost, think our cars have 2 of them. |
08-13-2010, 03:32 PM | #4 |
Rep 755
08-13-2010, 03:35 PM | #5 |
Rep 755
08-14-2010, 08:37 AM | #8 |
Rep 755
Had the car on a dyno this morning and my suspisions have been confirmed.
Peak bhp: 343 @ 4rpm peak torque: 423 I'll try to post the graph up on Monday!! The the graph shows the power peak at 4rpm @ 343 and then completeley flat line to 6.5rpm. As I said when the adaptations were first reset the car wad stronger much higher up the rev range and after a few days dropped of. The dyno has relayed exactly what I wad feeling in the car. Still not fault codes but the car is definatley raining in the power for some reason. Given it's strong tourqe output I don't think this is a boost leak. More lke a sensor is faulty but not enough to throw a code?? Anyway I'm down 30 bhp and needs some suggestions?? Cheers!!! |
08-14-2010, 09:24 AM | #10 | |
Rep 755
I belive the vanos solanoid controls the timing somehow anyone agree with this. Anyone know how much it is to change the vanos solanoid? Cheers!! |
08-14-2010, 02:14 PM | #11 | |
Rep 8,972
the diverter or dump valves just release excess boost on a closing throttle. maybe you should check again with rob? |
08-15-2010, 09:41 AM | #12 |
Rep 755
OMG...
I'll forgive you all for starting to think I'm bonkers!!! However, following the dyno run yesterday my car is now going Stupidly quick and I mean quick. Quicker than it's ever been before infact so bloody quick that it kept up with a Lamborghini Murciélago, I'm absutley astounded at it's pace!!! Don't know what the hell is going on but the dyno run must have cleared something out like a blocked fuel filter or somthin?? It's also Purring like a kitten and I'm SUPPER chuffed, just got out of the car with a mahoosive smile on my face!! Hopfully this is it for me know and I can't start enjoying the car again.b |
08-15-2010, 10:19 AM | #14 | |
Rep 5,493
And what makes the actuators move? Vacuum pressure, controlled by a boost solenoid Boost solenoid - This is the tiny device that controls the vacuum pressure to the wastegate actuator. If the solenoid fails, the car (via the ECU) cannot generate the correct vacuum pressure to close the wastegate, so therefore the wastegate remains open and you lose boost pressure. There are two boost solenoids on the car, one for each turbo. They are a bitch to get to as they are behind the wastegate assembly so not so easy to replace. Cost is quite cheap - can't remember the exact cost but £40 for both seems to ring a bell.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
08-16-2010, 02:43 AM | #16 | |
Rep 8,972
In my naivety I thought things would have moved on since my last turbo adventure on a 94 Sapphire Cossy. The cheap little plastic boost solenoid seemed a crude method, even then, of controlling the vacuum level. I didn't for one minute think our N54 would still use such a thing!! |
