Who has a snows dual nozzle methanol injection?
08-14-2010, 09:55 PM | #1 |
Vorstiener
17
Rep 364
Drives: 07' e90 335
Anyone else have a highly modded 335 w jb3 and bolt ons and the dual meth setup???? If so....
What do u have your controller set to? Boost solenoid activates? Power solenoid activates? Only reason I ask, is that I took 2 runs on the dyno today, first run was 305 w my methanol, then I turned the meth off and made 357hp WTF...I wanted to Anyone know what I'm doing wrong? Can anyone help me understand what I need to do? Btw my meth/h2o mix isn a 50/50 mix. And I am running all mods in my sig, plus the jb3 is at map 7 right now.
| 2007 335 e90 | KW V3 | AR DP | ICONZ | AFE | JB3 | VORSTIENER | MTEC | 3D DESIGN | SNOWS | STETT | FORGED DV | VANGUARD | GODSPEED FMIC | |
08-14-2010, 10:00 PM | #2 |
Rep 3,588
Hmmmmmm thats crazy!
honstly bro 50/50 mix is a big waste of time&money switch over to 70/30 i'm runnig a dual nozzle setup without a controller and it's perfectly fine. I'm running the Coolingmist basic kit with cm5 & cm7 nozzles 90/10 mix and she flys! |
08-15-2010, 12:10 AM | #3 |
LINEITUP
58
Rep 725
thats not right ! .. im running a dual nozzle snow kit on my car. M5+M7 nozzle.. i ahve it set to start at 9psi and go full at 13psi... without meth the car feels like a slug ...
08-15-2010, 10:42 AM | #4 |
Vorstiener
17
Rep 364
Drives: 07' e90 335
Ttt
08-15-2010, 11:02 AM | #5 |
Joint Chiefs of Staff
4927
Rep 116,037
I run the dual nozzle cooling mist kit. Meth starts flowing at 7psi and full flow at 12 psi. I have it set to map up to map8 or 9 once meth is flowing.
Running a cm7 and cm5 nozzle and spraying into a dual bung meth elbow. I also run an 80/20 mix. Mike |
08-15-2010, 06:12 PM | #8 |
Vorstiener
17
Rep 364
Drives: 07' e90 335
I wonder if i might have switched the power and boost solenoid by accident..
So it's sprays through the larger atomizer first? I'll try the 9 and 13 full I was orig on 7 and 15 full
08-15-2010, 07:47 PM | #10 |
442
Rep 18,331
Check the install again...There is no way you should be making less power with meth than without it PERIOD....Recheck your wiring and get back to us on what you f-up on!
Also up the 50/50 mixture to at least 70/30 for better results once you find your problem |
08-15-2010, 08:30 PM | #11 |
Rep 5,689
I run 100 no problem
Also 15psi is too high See what you are running at redline and set it 3/4-1 psi lower so there is no chance that you are not at full spray where it is most dangerous to be without.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
08-15-2010, 09:30 PM | #12 | |
Rep 4,732
08-16-2010, 02:43 AM | #14 |
Vorstiener
17
Rep 364
Drives: 07' e90 335
Thanks guys ill check my setup again and get back to u
power nozzle is closer to the intake manifold correct? Im hoping my meth nozzles are just reversed
08-16-2010, 05:26 AM | #15 |
Rep 5,175
Have you logged timing advance? Are you sure you aren't spraying too much and causing quench? Remember despite the forums belief that more is better, just start small and inch up. I started dual 100 ml/min and just started to go up. In my testing, a 150 ml/min and 200 ml/min was more than enough without nitrous.
