I Tested out Whether 50 Meth/50 Water Will Burn
08-15-2010, 11:01 PM | #1 |
Modder Raider
759
Rep 8,633
Drives: M3
I wasn't out to prove either way if it would burn or not.
I just really wanted to know and see the dangers behind it. So, I filmed the process and I'd like to hear your thoughts. I would really like your technical iunputs please. This is what I think... - It will burn if it is puddled or in large quantities because the meth doesn't have a chance to evaporate in large quantities. - It will not burn if it is spraying/misting since it evaporates almost instantly unless you spray it directly on a large flame. What I didn't test out is heating up a piece of metal to 500 + degrees and spray the 50/50 mixture on it, but I'm thinking that the heat will just make the meth evaporate. If you trust me with the actual 50/50 mixture and you just wanted to see it burn or not burn then you can just skip to the 5 minute mark.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
08-16-2010, 01:04 AM | #4 |
Rep 7,789
So basically, everyone should start running 60/40 mixture or higher in order for it to burn properly and right away correct ? Of course this is just an assumption, but 50/50 definitely doesn't burn as much as i expected, actually it barely burns at all.
Thanks for the test Mr.5 ! |
08-16-2010, 01:54 AM | #6 |
Rep 322
LOL, I think Mr.5 is doing this from a "safety" POV vs. "performance". We all know that high meth/water ratios are very flammable, probably he's trying minimize this and still get performance?
08-16-2010, 02:28 AM | #7 | |
Rep 7,705
i'll be stick to the good'ol "Boost Juice" 49/51 that EAS sells. |
08-16-2010, 03:13 AM | #9 |
Rep 549
Appreciate all your testing and comments.
When do you have time for family and work??? Would like the time warping device you have at your disposal, cause I don't get to do all the fun stuff you do... |
08-16-2010, 11:57 AM | #11 |
N54 FTW!
25
Rep 389
5,
To answer your original questions, your understanding of what burns is backward, it's not the liquid methanol that burns, it's the vapor. And the methanol vapor needs to mix with enough oxygen to reach the lower flamable level. That's why it burns when in a large puddle, methanol evaporates and then mixes with enough air (oxygen) to sustain the exothermic oxidation reaction (flame).
Pure Stage 2/Vorsteiner/Supersprint/Helix V2/KW V3/Brembo/H&R Sway/Volk RE-30 + Sport Cups/Procede + Meth/AR Design + OEM Oil Coolers/M3 CF Trim/LED Steering Wheel/RIX Guage/Blacklines/GC Hybrid Camber Plates/Spec 3+ Clutch
08-17-2010, 12:11 PM | #12 | |
Rep 516
07 e90 335i 13 mk6 GTI 13 f30 335i |
