PROcede launch control & progressive methanol injection
08-16-2010, 12:20 PM | #1 |
Rep 966
Question for Shiv - How do 6AT launch control and progressive methanol mapping work together?
Do you build enough boost using launch control that meth starts spraying and you're transitioned to map 2 before launch? |
08-16-2010, 12:23 PM | #2 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
08-16-2010, 12:28 PM | #3 |
Rep 10,587
has anyone looked into a higher stall converter for these cars? Possible? Is there even one used lol.
could make for some serious axle bustings launches.
08-16-2010, 12:30 PM | #4 |
1750
Rep 17,960
Drives: A Lot
If you tried our 6AT launch control function with fully warm slicks, you wouldn't want a higher stall converter. It will already cut 1.5-1.6s 60' times with the two foot to the floor method
08-16-2010, 12:40 PM | #7 |
1750
Rep 17,960
Drives: A Lot
08-16-2010, 12:46 PM | #9 | |
Rep 10,587
couldnt hurt!! a 4,000rpm launch w heated slicks and LSD would be amazing. The 6MT gang COULD make that happen once in a blue moon, but the AT guys could nail a fast 1.4 or something crazy like that. what rpms will the AT launch at anyway? example of high RPM turbo launch w a AT...filmed this at MIR last year.
08-16-2010, 12:47 PM | #10 |
Team Zissou
3084
Rep 10,198
I can launch at 5000 rpms with no issues
08-16-2010, 12:47 PM | #11 |
1750
Rep 17,960
Drives: A Lot
Somewhere around 2700rpm, give or take. It's been a while since I used the feature myself, being a 6MT owner
08-16-2010, 12:47 PM | #12 | |
Rep 518
I usually turn off DTC, pump brake and move gas pedal down to ~3,500 rpms. Even at my 1.8 second launches, it gets you pretty light headed. |
08-16-2010, 12:50 PM | #13 |
Rep 10,587
oh yeah?? Video
Id like to see a xi cut a 1.5 or under at the strip. I want to see a n54 powered car launch like this one day.....Donovan is the man. You can see a typical 335 launch in the other lane, at least for a split second then its out of the frame.
08-16-2010, 01:03 PM | #14 | |
1750
Rep 17,960
Drives: A Lot
Again, you need FULLY WARM drag tires to be able to put all that power to the ground. For those who haven't used this feature, you'll be shocked at how much power your car can make right off the line. Shiv |
08-16-2010, 02:21 PM | #16 |
Rep 3,868
Drives: E93 335i
Is it preset or can it be adjusted, e.g. 2,000 or 2,400 RPM ?
12.770 @ 112.81 mph||slip||JB4|FMIC|DPs|DCI|N54 DVs|ER CP|Koni FSD|Eibach-Pro|F Strut-bar|R Sway-bar|Hankooks V12|DPE SP16|BBK|15%Tint|CF Front Lip|CF Diffuser|M3 Spoiler|SmartTop|LUX AE|Debadged |
08-16-2010, 06:03 PM | #17 | |
Rep 966
My controller is set to start spraying ~7psi and I think I remember datalogging almost 10psi using boost control at launch, so I should be transitioned to map 2 at or soon after launch. Looking forward to trying this again in the fall! |
08-16-2010, 06:13 PM | #18 |
Rep 4,647
exactly. i tried launch control with street tires, it was uber fail, even slower than 2000 rpm launch. with proper tire setup, it will be worth it i guess...
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
08-16-2010, 06:24 PM | #19 |
Rep 966
08-16-2010, 06:36 PM | #20 |
1750
Rep 17,960
Drives: A Lot
08-16-2010, 06:54 PM | #21 |
Rep 6,473
