Upgraded turbos in your future? Check your...
08-17-2010, 07:39 PM | #1 |
Vengeance is mine, I shall repay
132
Rep 4,656
Soo....I've been testing my car with the EPL upgraded turbos and I have to say they are amazing....GOBS and GOBS of power....but today I tried a launch using the V4s launch control and well basically I blew my axles...or at least I think....loaded up to 2600 loud bang no movement...no smoke , no leaking, no codes but when I put the car in park it makes this crunching sound but only when I put it in park.....not d or r or n.....just park.
***READ THE UPDATED TITLE***
Project: Vengeance[ACM's King of domestics, STOCK:501whp 489wtq | 2.9L whipple stock bottom end: 706whp 688wtq] Callies Compstar motor build:NEXT
08-17-2010, 07:43 PM | #3 |
132
Rep 4,656
08-17-2010, 07:48 PM | #6 |
442
Rep 18,331
It could be the half shaft..FBIS wanted to upgrade his
http://www.e90post.com/forums/showthread.php?t=418969 Either way did you hit up Matt and see what he thinks... I would think he would know for sure |
08-17-2010, 08:00 PM | #7 | |
132
Rep 4,656
08-17-2010, 08:07 PM | #10 |
Rep 1,794
I've had one auto transmission break on me before and it made crunching sounds like you described. It made the noise when I put it in drive and reverse though and the car would not move.
08-17-2010, 08:09 PM | #12 |
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
Maybe the guibo is gone? Probably more than that though....
08-17-2010, 08:16 PM | #13 |
132
Rep 4,656
Yea....I'm hoping it's something minor....the thing that gets me is that the car didn't throw not one code...
08-17-2010, 08:21 PM | #14 |
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
The Fast and The Furious Because They Busted Their Car...
Nothing personal, but you'd think people would be aware that a stronger engine with way more torque than stock needs a stronger driveline, especially when abusing it (hard launches, etc). It's likely going to be a trans component, and those ZF automatics are pricey.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-17-2010, 08:26 PM | #15 | |
132
Rep 4,656
08-17-2010, 08:34 PM | #16 |
442
Rep 18,331
Wow if its a total tranny that needs to be replaced I would try to see if there are any possible upgraded parts...Damn these AT tranny are expensive...Hopefully you can get it under warranty man...
08-17-2010, 08:38 PM | #17 |
132
Rep 4,656
Yea....I took the v4 out and cleared all codes...if it isn't covered under warranty looks like I'll be filing a claim by the end of the week....anyone ever file a claim for mechanical issues before?
08-17-2010, 08:38 PM | #18 |
Rep 3,334
Doesn't the procede delete codes right away?
Mods list got too long, lets just say more than enough.
08-17-2010, 08:42 PM | #19 |
132
Rep 4,656
Yea but would have thought a tranny code would persist even after I took out the v4....but it didn't...
08-17-2010, 08:43 PM | #20 |
Rep 811
I almost guarantee it's not the trans.... Follow me here for a sec.
It sounds like something let go that was beyond your trans (driveshaft, half shaft, differential, etc) When that happened, your trans was spinning freely at the output shaft where your parking pawl is located. When you threw it in park, it simply sounded like grinding as it couldn't drop into the drum rotating beneath it. Same as throwing your car in park before you come to a stop. That's not our trans, but it shows the "hole" the pawl has to fall into so that Park means stop driveshaft rotation. Here is a REALLY simple test. Put your car in park, e-brake off, and see if you can push it forward or backward.
'08 TiAg E90 335 M-Aero kit. - SOLD
08-17-2010, 08:49 PM | #21 | |
132
Rep 4,656
So if the car moves while in park does that prove it's not the tranny?
08-17-2010, 08:50 PM | #22 |
Team Zissou
3084
Rep 10,198
