Help! setting up JB3 Datalogging
08-17-2010, 08:56 PM | #1 |
Rep 267
Drives: 2007 E93 Alpine white with Red
Does anyone have any "datalogging for dummies" directions for datalogging with the BMS cable? I already have it run though the firewall and pulled through the glovebox - literally all I need is someone to show me where to get the software, how to install it, and how to install the drivers etc.
I already have a JB3 2.0 I dont need to change anything with the tune, just want to datalog and read values. thanks!
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
08-17-2010, 09:06 PM | #2 |
Rep 811
Datalogging directions:
To being recording click “file” “connect” to establish communications with the JB3. If you fail to connect, ensure you’ve selected the appropriate communications port under settings. If the RPM and other signals are moving around below you are recording. If you have stopped recording for any reason and want to restart or reset a log you can click “data logging” “start”. The interface will store up to 5000 data points. If you have samples / second set to 10 under settings this will yield a maximum of around 8 minutes of recording time per log. At the conclusion of your runs/log, click “data logging” “stop and display” to stop recording and plot the datalog. Parameters can be added or removed from the display by clicking the “add” button next to each. If you want to save the log for later, or email to BMS, click “data logging” “export” “csv” and save the file. You can click “data logging” “open CSV” to study the log at a later time. All parameters will be always saved in the CSV regardless of your viewing settings. Use the “data logging” “X Axis” menu to adjust the scaling or filter out non-WOT activity. With longer logs and slower computers scrolling through the display can be slow, so limiting viewable data to near WOT activity only can be a time saver.
'08 TiAg E90 335 M-Aero kit. - SOLD
08-17-2010, 09:08 PM | #3 |
Rep 267
I'm not even there yet.... Literally.... I need basic instructions. What drivers do I need. Do I just plug my computer into the JB3 and it will automatically work? I'm a car guy not a computer guy.... and to make it worse I simply cant find any instructions.
08-17-2010, 09:27 PM | #4 |
Joint Chiefs of Staff
4927
Rep 116,037
Just download from here....
http://www.n54tuning.com/index.php?_a=viewDoc&docId=5 Instructions in the zip files! Mike |
08-17-2010, 10:31 PM | #5 |
Rep 267
Got it, Thanks guys!
