Removing Procede - necessary to disconnect battery 1st to avoid codes 4 dealer visit?
08-19-2010, 11:21 AM | #1 |
Rep 978
So far, out of an abundance of precaution before dealer visits, I've always disconnected the battery before uninstalling the Procede, as I thought I'd read that you might throw a code otherwise during the uninstall. I don't recall it being needed from a safety point of view (in that otherwise, you might fry the ECU, for example).
Is that true? It adds another good 20 minutes to my process (I've got an E93 and the battery's a PITA to get to), and would be nice to avoid this step... |
08-19-2010, 11:40 AM | #2 |
Rep 2,491
Drives: 991 C2S Guards Red
its not necessary. Pop the hood, lock the car, let the ECU "go to sleep" (about 10 minutes) before uninstalling and you should be fine. I understand the precaution though, so by no means am I saying that it is bad idea to unhook the battery. I'm so paranoid that I use a BT scanner afterwards JUST TO MAKE SURE (), but I've never seen codes from taking it off. Like a lot of people say though, putting the value of your warranty to a few more minutes puts things in perspective
991.1 C2S PDK, Guards Red | PDCC | Sport Chrono + | Clear Tail Lights | Alcantara Steering Wheel | HRE FF01 | TechArt Springs | Sport Exhaust
Previous: Porsche 997 Turbo 6MT, Atlas Gray | Cobb Stage 2 | HRE FF01 | Europipe Stg. 2 Exhaust | GMG LMS Rollbar | GT2 Exhaust Tips | Pagid RS-29 | Rennline Pedals | SSK 997.2 Track Car, heavily modded & E92 M3 DCT, still miss her daily & E92 335i heavily modded |
08-19-2010, 11:51 AM | #3 |
How you like them apples?
41
Rep 1,492
Drives: 335i
V5 rev2.5 | VExhaust | V1 KW | V701 | H&R Sway Bars | Ram Air Scoops | DCI |
08-19-2010, 12:13 PM | #5 |
1750
Rep 17,960
Drives: A Lot
08-19-2010, 01:46 PM | #6 |
Rep 2,760
I cleared codes, set it to valet mode drove to dealer a few cities away. Yes they did update my ECU and no issues at all. I didn't hear a peep from any soul.
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
08-19-2010, 02:22 PM | #7 |
Rep 1,565
Can someone verify then the following:
1) Manually Clear Codes, just to make sure. 2) Extra precaution, disconnect battery. 3) If not disconnecting battery: Turn Car off, Lock Doors, put keys inside, let car go to sleep for 10min. 4) Remove Procede. 5) Make sure it is nice and clean, buttoned up properly. 6) Plug Selenoid for Exhaust back in located in trunk. Sound Ok? Make corrections please if any are needed to that list.
2020 M340i: Dravit Grey Mettalic. Loaded.
08-19-2010, 02:38 PM | #8 | |
Rep 978
Shiv, what are your thoughts on the disconnecting battery thing? Ever seen a code if it's done correctly? Last edited by Glowin; 08-19-2010 at 06:20 PM.. |
08-19-2010, 03:48 PM | #9 |
Rep 840
I remove it without disconnecting the battery and I haven't had any issues or codes. I try not to open any doors or the trunk, and make sure that the ECU goes to sleep, which in my case doesn't take longer than a few minutes.
Also keep in mind that you should keep the key fob away from the car during the install if you have Comfort Access. |
08-19-2010, 08:35 PM | #10 |
Rep 3,432
Did you try The BMW Store? I never have to remove ANY mods (tune, intake, dp, exhaust) when I go there for service. Just got micro filter replaced today, was also due for program update (recall for hpfp as I'm told), but I chose to not have it done since my car runs perfect. Only thing I did was put it on stock map.
I did work there for like a month awhile ago, maybe that helps? But that just shows how important it is to have good relationship with dealer or SA. I would still say they're just better than BJ and AW. Last edited by Gen_E92; 08-19-2010 at 08:41 PM.. |
08-19-2010, 11:40 PM | #12 |
Rep 3,432
08-20-2010, 02:29 AM | #13 | |
Rep 320
