HELP! My car wont move.. Rear right wheel locked up.
08-22-2010, 06:15 AM | #1 |
Rep 38
Was driving along at 40mph and was hearing this ticking noise that was getting louder out the window. Stopped at a traffic light , then when i tried to pull away the car was struggling like it had a flat tyre.
Got out to check, everything on the car was fine, tried to pull away again and the car was struggling, making horrendous wrenching noises as it was moving, then parked in a safe place, tried moving it but was basically impossible without applying a lot of gas so i left it. Called the AA, he took the wheel off and he tried to take the brake disc off to take a better look, but the disc was really stiff and wasnt coming off. He said the wheel hub had completely locked up but he wasnt sure why. Had to get the car recovered. Anyone got any ideas what might have caused this? Last edited by MarvinMarvin; 08-22-2010 at 07:45 AM.. |
08-22-2010, 08:20 AM | #2 |
Kingslayer
411
Rep 1,479
If the hub is locked and not moving it sounds like the wheel bearing failed. It could be a frozen brake caliper but from what you described it sound more like a wheel bearing.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i Current Cars: 2019' X3, 2021' M3 Comp |
08-22-2010, 08:27 AM | #3 |
No 55mph
1623
Rep 8,479
Sounds as if your Parking Brake setup is FUBAR on that side. The parking brake is comprised of a set of 'old style' brakes shoes such as found on drum brakes that are contained inside the hub of your rear disks.
Parking brake must be stuck in the 'ON' position inside the disk - hence the reason you can't get the disk off... The disk bolts to the hub flange, so regardless of whether the bearing was bad or not, the disk would still come off the hub Here's an example (not your exact car, but same idea) the brakes shoes in the pic actually are inside rear disk hub and use that inner surface to do parking brake duties.
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
08-22-2010, 08:33 AM | #4 |
Rep 38
Actually the AA guy did mumble something about shoes which i didnt really catch when he was trying to take the disc off. Its a manual car btw, so by parking brake you mean handbrake? What can cause it to be permanently in the on position? i.e is it covered by warranty?
08-22-2010, 08:36 AM | #5 |
No 55mph
1623
Rep 8,479
Yup, that would be the handbrake - lever on your console.
Hard to say what went wrong without looking at it As far as warranty goes, depends on whether your car is still under warranty - if so, then it would be covered
08-22-2010, 10:07 AM | #6 | |
Rep 38
The car is 2008 build so still under warranty. 58 or 08 in the registration plate of the car indicates the year in the UK. 59 or 09 for 2009, 60 and 10 for 2010 and so on.. |
08-22-2010, 10:21 AM | #7 |
Rep 2,373
not sure what your issue is-but FYI ive NEVER seen a wheel bearing be so bad it locked up...nor a bad bearing in general without making some CRAZY noises for long periods before hand...
08-22-2010, 10:38 AM | #8 |
No 55mph
1623
Rep 8,479
If the parking brakes are locked 'ON' I would assume they would try to release them from backside at cable - last recourse is to use a disk puller to mechanically pull off the rotor (that might mess up things further tho).
I had an auto car & never used the parking brake. Wife borrowed the car - I warned her NOT to use the parking brake as it was prolly rusted up from non use. Do you think she listened? I get a call @ work with her crying (literally) that she is stuck at the Sheets 3mi down from our house and the rear brakes are smokin bad. I get there to find that the wheel got so hot in that 3mi from brake being stuck ON; that the plastic hub cap started to melt I had to remove the wheel in the parking lot and manually release the parking brakes with pliers... Since you have a manual, I would assume you use the brake all the time - so rusted up is prolly not an issue - must be something else. When asked, she did state that the car seemed sluggish & acted like it didn't want to move. And yes, for a wheel bearing to be that bad to actually lock up a drive wheel (have never seen or heard of this) you would have heard hell of a lot of noise from some time back. Report back with the final result - I am curious
08-22-2010, 10:41 AM | #9 |
I ask the questions you're afraid to ask.
44
Rep 2,489
01-18-2011, 08:11 AM | #10 |
Rep 38
Its got sorted.
A while back i must have clipped the curb with my back wheel while driving or parking, and it turns out that one of the wheel bolts snapped through the middle - while still inside the wheel/hub/etc.. But the head of the bolt was still stuck in the wheel.. making it look like all 5 bolts were still holding the wheel onto the car. Turns out over time, the shaft of the bolt slowly went in further and further into the hub, until it had pressed against something (cant remember what exactly) and locked the wheel up - stopping it from moving. The fella from BMW assistance came and rather than towing it (which was what he was meant to do) he took apart the wheel and the hub and got down to the problem within 15 minutes. |
01-18-2011, 08:35 AM | #11 |
Rep 7,089
Drives: '06 AW 330xi
Nice. Glad you got it sorted out. I once replaced my rear rotors and forgot to disengage the hand brake before taking them off.....Im an idiot lol
Does any one know when to replace the handbrake? Mine makes a click sound when parked on a hill and I roll back on it. OP, so it wasn't the wheel bearing? The bolt got stuck in-between the parking brake and hub? EDIT: Nevermind. I think I know what your saying. The bolt slowly twisted itself further into the hub and acted like a set screw right? |
01-19-2011, 12:03 AM | #12 | |
Rep 38
01-19-2011, 07:28 AM | #13 |
Mad Linux Guru On The Loose
1130
Rep 5,400
I've been driving a manual cars for my entire life and I never leave the car parked with the ebrake on. Ohh, and this is not a parking brake it is an emergency brake!
You should never leave your car with e-brake on. If you have a manual transmission, just leave the car in 1st gear.
01-19-2011, 09:28 AM | #14 |
Rep 712
Black matte paint? Looks nice!!
SOLD - 2007 BMW 335i Sedan, Montego Blue with Lemon seats, AluFelgen CS7 rims & Continental DW tires
CURRENT - 2018 Chrysler 300S, Crystal Granite Metallic. |
01-19-2011, 09:58 AM | #15 | |
Rep 423
I do the same with my automatic transmission now- I have it on P, then engage the handbrake as well- to relieve the transmission of unnecessary stress when on an incline. |
01-19-2011, 10:16 AM | #16 | |
Rep 7,433
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
01-19-2011, 10:41 AM | #17 | |
Rep 107
And no Vasillalov, it is not an "emergency" brake, it's a PARKING brake. Check your manual. |
