Car overheated. Has my water pump failed? vids inside
08-22-2010, 10:08 PM | #1 |
Rep 2,090
Hey guys, my car overheated yesterday for the second time within the last 3 days. I would just pull over, turn it off and let it cool down. When I opened the hood, I noticed that there was some coolant that was released. Luckily for me I was only a few miles away from my house. I finally got home and scanned my car and had 2 codes. Both have something to do with my water pump. 2 weeks ago I also got a low coolant warning. I went to the dealer and picked up some coolant and just topped it off. Also, my car has been making this weird vibrating noise for about a minute after I go on a long drive and turn the car off for the last month or two. I put my car through the water pump cycle or flush thing and made a video and this is the weird vibrating noise I'm talking about. Tell me what you guys think. Has my water pump failed?
08-22-2010, 10:16 PM | #2 |
Rep 3,161
have it checked out. My friends 335 had a crack in his radiator and BMW replaced it.
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/ SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/ SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/ |
08-22-2010, 10:33 PM | #3 | |
Rep 2,090
i have my other bumper at ltbmw and need to get it put on before i go to the dealer because my current bumper is too low. it is about an 80 mile trip there and back.
08-22-2010, 10:40 PM | #4 |
Rep 6,473
Why don't you just pressure test the cooling system to see where the coolant is coming out from? BMW's usually crack the the radiator tanks or overflow tank. If it's a large crack and cannot hold pressure, then there is no way you can make it 40 miles.
08-22-2010, 10:44 PM | #5 |
Modder Raider
759
Rep 8,633
Drives: M3
The noise after the car is off is normal to cool the turbos.
I think the pressure test is a good idea.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
08-22-2010, 11:13 PM | #6 | |
52
Rep 428
But whatever you do, definitely don't drive it around until the issue is fixed or else its likely that you will be left stranded somewhere. Once coolant temps go too high, your dme will trigger a low power/low throttle limp mode which is decent enough for normal driving. The problem is that I can see irreparable damage being done with driving around with an overheating engine for too long. |
08-22-2010, 11:56 PM | #8 |
Rep 811
Totally, it's the only car that ever has a water pump go out. You should stay away.
'08 TiAg E90 335 M-Aero kit. - SOLD
08-23-2010, 12:28 AM | #9 |
Rep 408
Procede Inside! AutobahnExotics, Vishnu DCI, AR Oil Catch Can, ETS Black Anodized Intercooler, Quaife LSD, Falken FK452, Mtech 6000k HID, 7000k Halos, 15%vlt Ceramic Tint, Matte Black Kidney Grills.
08-23-2010, 01:19 AM | #10 |
Rep 306
Yeah but the sound i hear in his video is not normal , sounds like a pump that is running dry and then seizing or something , then starting again and seizing again.
335I AT 2007. Vishnu V5 / UR CAI / HPF Intercooler / ER Charge pipe / Synapse BOV / Macht Shnell dp's / Vanguard catless exhaust / BSH occ / Labonte S4 Meth injection / Quiafe LSD / Full M3 suspension parts / Bilstein PSS10 / EBC brakes and lines / RB turbo's
08-23-2010, 01:22 AM | #11 |
Rep 2,090
thanks guys and thanks calvin for your detailed response. i figure that is exactly what the problem is because i am at 63,000 miles. so i just dropped my car off right now to the dealers for the early bird service.
08-23-2010, 01:23 AM | #12 |
Rep 2,090
thats what i was thinking. im really worried about it.
08-23-2010, 09:10 AM | #13 |
Blah blah blah
Rep 149
If a rare water pump failure scares you away, then you definitely won't be shopping for an S4. Google: B8 S4 water pump
The Evo also had a recall on water pumps...I know, i had one pop the weeping hole while on a road course. Unfortunately, as someone else said, the accessories on a performance car are often weaker than the motor. My cache of spare parts for the track included pretty-much every accessory, belt. hose, etc.
Ian 2009 e90 MT
08-24-2010, 11:59 PM | #16 |
Rep 2,090
bump
hey guys i just got my car back today. they said my battery that was the problem? i had low voltage codes i had to buy a new one. and now my car isn't overheating anymore and no more water pump codes.. anyone have an explanation on what the battery had to do with this? but I am still getting that weird vibrating noise when i turn the car off. maybe mr. 5 was right? this is just for cooling reasons? anyone else have this also? thanks!
08-25-2010, 12:07 AM | #17 |
3442
Rep 79,211
Holy crap dude WTF?
That noise is ridiculous. There is a very unnoticeable noise when the car is off, slight humm. <--- NORMAL Your car sounds like the 4th of july/ jack hammer... something is definitely broken. |
08-25-2010, 12:14 AM | #18 | |
Rep 2,090
any ideas what it could be? i was doing some water pump flush thing that i read about in a thread. it goes on for like 12 minutes so it was just this sound constantly. when it happens when i turn my car off its only for like 30 seconds. the dealer wrote vibrating noise-aftermarket equipment installed-coilovers wtf?? and also..when I WOT the car now and come to a stop you can hear the fan pretty clearly for like 5 seconds and then it goes quiet again.. is that normal?
08-25-2010, 12:21 AM | #19 | |
3442
Rep 79,211
I would stop with the pump flush, I think your pump is toast in some fashion. The pump recirculates coolant through your turbos after you shut it off (the car)to cool them down slowly. Naturally, when you WOT the car, engine is going to heat up, so I suspect your fans are kicking on cause your coolant temp exceeded a certain temp... I'd be concerned about your thermostat and the rest of your cooling system components at this point. If you have BT tool, check your coolant temps and see how they are responding. Eitherway bring it back to dealer. |
08-25-2010, 12:44 AM | #20 | |
Rep 2,090
anyways thanks a lot jpslick for your help.
08-25-2010, 04:50 PM | #22 |
Rep 3,012
I had an over heating issue, it was a battery issue with my terminals, although my car operated perfectly fine. Electric water pump is better than a mechanical pump in case it seizes up and that can cause havoc on some cars with cams connected to that pulley.
Tags |
335i, e92, overheated, water pump |
