will the key data stay on the the key if i get a new fob?
08-24-2010, 11:29 AM | #1 |
Rep 24
hi
ive got a query which i would like an answer to. i know the key fob store info such as seat positions, radio stations, last time key was used etc etc, but if i put the metallic key into a new fob and got it programmed what info would stay on there? or is the info stored in the actually fob and not the key part. could anyone also confirm if any info would pass over onto the new fob if it WASNT was reprogrammed? Cheers |
08-24-2010, 11:34 AM | #2 |
Rep 8,972
The fob itself doesn't store the data AFAIK, the car stores the data and 'recalls' it by linking it with the unique ID of a key fob.
The metallic key is just for emergencies and has nothing to do with anything electronic or memory wise. I think you will have to just reset everything when you have a new key. Maybe if you leave the car open (having been opened with the old key) then lock it with the new key then the new key will be set for all the current preferences at that time. |
08-25-2010, 01:51 AM | #3 |
Rep 497
08-25-2010, 03:12 AM | #4 |
Rep 13,043
Drives: BMW M340I G20
I thought the key did store data, in the past dealers have plugged my key into a dock thing on the service desk and read data from the car.
08-25-2010, 03:27 AM | #5 |
Rep 1,800
Yeah, I think the fob must store it.
If not, then the only way the dealer would know the info from the key is if the car sends data to BMW over GPRS, and the key then points the dealer to a central database at BMW. But, I reckon, if you get a new key, the first time you use it in the car, the car will re-load all the data.
Black 330d E90 LCI M Sport Saloon Auto. Privacy Glass, Cream Leather, 6FL, I-Drive/Nav/Bluetooth, Alpine hifi upgrade.
08-25-2010, 04:26 AM | #6 | |
Rep 8,972
But user preferences are stored in the car (can't remember where I read this) that's why the car can only handle up to a maximum of 4 keys of 'preferences'. If the fobs held all the data then the car should be able to handle unlimited numbers of user preferences. The crowded standard fob frequencies would make data transfer very slow and problematic as they are intended for only minute bursts of coded signal. The user preferences are a lot more than a few text fields of service data. There will be all the position coordinates for seats & mirrors, air con settings, audio visual settings and all stored favourites etc. etc the list goes on. Too much for a fob to handle (cheaply and quickly) IMO when the car already has the data to hand and plenty of hardware to handle it. |
08-25-2010, 04:29 AM | #7 |
Rep 24
thanks for the reply guys.
So just to make sure, if i put the key into new fob no data will be on the new fob unless i use the fob and key in the car. |
08-25-2010, 04:37 AM | #9 |
Rep 24
sorry for my ignorance, but ive lost the fob and have got a new one and just wondered about getting it programmed or would it just work as normal.
cheers guys. |
08-25-2010, 04:41 AM | #10 | |
Rep 13,043
Or are you saying, when any given fob is pressed, the car recognises the fob and starts moving things around before the door's opened? |
08-25-2010, 10:03 AM | #11 | |
LSD - No, you're not seeing things
72
Rep 3,302
The car knows what ID has what settings and applies them to the car. How that is handled depends upon how you have set that up in the car. With iDrive, you can decide in the menu if the seats move right away as soon as you press a valid keyfob, or if you wait until you pull open the door. Mine move as soon as I blip the fob, so does my wifes as its almost certain that I will wish to drive it |
