Need help want a wavetrac.
08-26-2010, 03:47 PM | #1 |
Rep 408
Hi everyone,
Done a search but cant find anything. Its time for me to get a limited slip diff, on my search I have found the yanks really rate the wavetrac. From the information I have gathered I feel positive that this is the product I'm after. So the big question, where in the UK can I get one from? and of course fitted? I have heard good things about birds but they seem only to deal with quaife and in the last couple of years or so their prices seem to go up & up every time I look at their website. Any input on this would be very much appreciated. Many thanks. |
08-26-2010, 05:46 PM | #2 |
Rep 5,493
Does your car have a bolted-style diff or a welded-style diff? If it is the latter, welded, then are you sure Wavetrac have a solution? I thought their diffs were only for bolted-style variants.
There's a reason why Birds only do the Quaife - it's the original, and it's bulletproof. And there's a model that fits every single BMW variant, bolted or welded. In reality, the prices haven't gone up - bolted diff is still £890 + VAT, same as it was two years ago. A diff for a welded crown wheel is obviously much more money, due to the amount of work needed.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
08-27-2010, 03:04 PM | #3 |
Rep 408
The car has a build date of dec 2006 I have been told that its a bolt on they knew by the number on the windscreen. My comment about the cost from birds was the unit fitted was £1200 plus vat now the same thing is £1336 plus vat if I'm wrong about these figures the I do apologize. Even so £500 plus vat for half a days work sounds crazy steep to me.
10-25-2010, 11:17 PM | #4 | |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
10-26-2010, 06:17 AM | #5 |
Rep 32
You should be able to order one through Co-ordsport.
http://www.coordsport.com Price List http://www.coordsport.com/attachment...010-Retail.pdf Had a look at one a while ago on a trip to the States and thought it was a very good upgrade to the non locking Torque Biasing type. Tried to get them to make one for the 7/7.5ich Ford Sierra diff for the kitcar market but they wanted a minimum order of 30. My only problem with the ATB type if that once you completely loose traction on on one wheel then this is obviously no driven force applied (one simple way around this is to apply the handbrake lightly and therefore applying friction so there is always some drive force). But they Wavetrac offers the best of both world in terms of a LSD, ATB daily drive-ability and the locking traction of a clutch/plate type. I am surprised Quaife have not implemented such a system as in my mind it would make their product so much better. |
10-26-2010, 10:39 AM | #6 | |
3893
Rep 54,605
Drives: F80 M3
The truth is(we have tried both) Wavetrac doesn't work much better when one wheel is off of the ground, the inside tires still spins. At the end Wavetrac may need a rebuild where the Quaife will continue to work as designed. |
10-26-2010, 12:20 PM | #7 | |
Rep 32
10-26-2010, 03:00 PM | #8 |
LSD - No, you're not seeing things
72
Rep 3,302
Thats quite an exceptional situation there friend
I also looked at the Wavetrac for similar reasons. But the reality is that for track work the ATB is just fine, and zero maintenance. No issues so far, and even with low articulation at the rear (stiff bars and springs) there is no wheel lift in daily use or on a tight and bumpy circuit.
10-26-2010, 04:14 PM | #9 |
Rep 32
Don't misunderstand for a daily driver I think the ATB type are without doubt the best solution but I do think the ability to ultimately lock the diff would prove very useful.
Having owned several Vehicles in which locking and in-fact being able to adjust on the fly the amount of slip I have found I used it more than I initially thought I would. Last edited by atomic69; 10-26-2010 at 04:29 PM.. |
10-28-2010, 12:58 PM | #10 |
3893
Rep 54,605
Drives: F80 M3
One thing to consider before buying the Wavetrac is that you are potentially looking at a rebuild of the single clutch pack down the road and the increase services to rid of the clutch material from one wheel off conditions.
Wavetrac really isn't much better than the Quaife during one wheel off. Okay, maybe just a little when the Wavetrac is new, but after several one wheel off, the single clutch is done. |
10-28-2010, 03:57 PM | #12 |
3893
Rep 54,605
Drives: F80 M3
