328i with auto tranny handles well?
08-30-2010, 09:06 PM | #1 |
Rep 2
Hi all, I currently drive a MB C280 (shut up) and want to move on to something sportier. I think the e90 328i will be a good fit for me. I plan to get one with the sports package. But yes, it will have to be automatic... because of the congestion here. For those of you who have one, does the e90 with auto still provide the most thrills in its class, compared to its competitors with automatic transmission?
08-30-2010, 09:18 PM | #2 |
Rep 6,594
Well, the best answer is to drive it yourself and see if you like it. The 328 and 335 do use different AT units. Both are 6 speeds and feature Steptronic, but the 328 uses a GM-designed unit (built in France) while the 335 has a ZF unit. The ZF unit is built to handle the added torque of the 335 and shifts a little quicker, but I don't think you'll be disappointed by the 328 AT.
X7 LCI // Incoming C7 ZR1 ZTK // Sebring + TRX // Hydro + Raptor Gen1 Roush // Tuxedo |
08-30-2010, 10:06 PM | #3 |
Rep 182
There is a bit of a lag when taking off from a standstill but once the car starts moving it does just fine. Basically you just have to give it a bit more gas than you think you need on takeoff. In sport and manual mode it feels pretty good, for an auto.
2011 e90 328i | Montego Blue | Black Dakota | Premium | Value Pkg. | STEPTRONIC | Nav | Harman Kardon | Xenon |
2000 Trans Am WS6 | Black | Black lthr. | Hurst 6MT | T-tops | Eibach pro kit | Koni SA | Borla | |
08-30-2010, 10:14 PM | #4 |
Rep 1,190
I have gotten many a 128i and 328i auto box for loaners, even had one for 1.5 weeks as spark plugs were being changed on my car(apparently they need the oldest monk to hand carve them from baby whale bones and then flown in to get put in my car :|). The engine and car is phenomenal. Even the ones without the sport package. It does thrill in ways that my n54 equipped coupe can not deliver.
BUT (everyone knew there was a but coming) the auto transmission has got to be the dumbest auto box I have ever used. It can't make up it's own mind when it comes to anything but puttering along. Sometimes the shifts were harsh and I found that it would down shift after I've already compensated for the slow take off.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
08-31-2010, 08:06 AM | #6 |
Rep 30
I am a 2007 328i owner with Auto and Sport. I like the way the automatic is set up in this car, in my opinion it is sort of a dual personality vehicle. In Drive mode it starts out in 2nd gear I believe, better fuel economy, upshifts quickly, good for around town. In DS mode it feels like an entirely different car - starts out in 1st, higher shift points, much more aggressive to drive. My prior car was a manual transmission, but I have been very pleased with the automatic so far in the 328.
08-31-2010, 08:10 AM | #7 | |
Rep 10,120
To the original poster. If you get the 328i then get a PBX. Perosnally, I wouldn't buy another 328i. Going for the 335iS this spring. |
08-31-2010, 09:25 AM | #8 |
Rep 1,452
I think a better way to determine if DS starts in 1st or 2nd is to count the shifts as you take off. Just because you downshift at a light in DS and it goes to 1st doesn't mean it's not already at first. Do you know what I mean?
08-31-2010, 09:41 AM | #9 |
Rep 2,848
Yes a 328i will be fine, I came from a w202 too...a 328i with sport pack will still be much better then the 280. If you can tho try and get a 335i you wont be disappointed.
08-31-2010, 09:49 AM | #10 |
derp
48
Rep 1,203
When you put the AT 328i in manual or sport mode it's as much fun as I could ever ask for. The lag in normal mode is killer though but you get used to it. You'll love it.
08-31-2010, 10:31 AM | #11 |
Zoom Zoom This
12
Rep 694
Mine is a 335 so a bit different but if its anything like mine at all, I would say go for it. I can hit the canyons in DS or M and then when I come out of the last turn I slide it into D and the adrenaline goes down at the same time the car turns into this docile (well as docile as a 335i can be) sedan that is quiet and comfortable, feels like no big hurry, just quiet and comfortable. It really does feel like a different car in D from DS/M. I guess since mine is a ZF I can't compare shifts but mine isn't harsh, it just does what I tell it. (I do have a minor annoyance in DS that when I'm hard on it and let off, it just kind of hangs there at 5 or 6k revs instead of upshifting and coasting but hey, it doesn't know I don't want to have fun anymore so it is still doing what its supposed to and holding it there for me to gas it again.....
08-31-2010, 10:32 AM | #12 |
Rep 10,120
No I starts in second.. Believe me you can tell when you take off in first vs taking off in second.
08-31-2010, 11:00 AM | #14 |
Rep 2,797
Drives: 2020 M4 ZCP / 2023 X3 M40i
DS starts in 2nd, because if you upshift at a standstill, it goes to 3rd. Also in M mode, it automatically goes down to 2nd when you come to a stop.
08-31-2010, 12:29 PM | #15 |
derp
48
Rep 1,203
There's only 1 thing I don't like about DS and M. When you're in DS and you're accelerating and you want to take control in M and upshift, sometimes it shifts up twice because DS was already planning on upshifting before you did it yourself in M. Had this car for 18 months now and I still can't get used to that...
08-31-2010, 01:28 PM | #16 |
Rep 10,120
08-31-2010, 02:53 PM | #17 | |
Rep 1,452
Ok, just make sure you calibrate it monthly.
08-31-2010, 03:13 PM | #19 |
Rep 287
OP, 328i is plenty fine, and coming from a C280, you will definitely love the improved performance and handling and road feedback that the e90 will provide.
In my opinion, those who bash the auto tranny in this car are mostly doing so due to their comparing it to 335i. The transmission in this car works beautifully, and as intended, and yes, it does very occasionally act confused, but mostly because the driver confused it. The DS mode does start from 1, not 2. Come to a full stop in DS, and as it is approaching the full stop, it puts it into 1, hence creating that sudden slowdown that some people (like me) are upset about and consider a 'rough' engagement. When you start from a red light in DS mode, it does indeed start in 1, and it upshifts to 2 as needed... i.e. depending on how much gas you are giving it, it may hold the first gear for longer, or quickly switch to 2nd if you are not pushing it hard enough. This has been the behavior of mine and every other 328i that I have driven (loaner, etc.). The fact that you are stopping in DS and downshift (while stopped) and it goes to M1 doesn't mean it was in M2... it means it is now in manual mode but still in gear 1. Anyway, the only reason that I say the driver can 'confuse' the transmission is this: this car does not have the flat torque curve that 335i has... so the transmission has to make up for it if/when a sport mode is desired. Like in any other machine with great amount of torque down low, a transmission doesn't need to shift to lower gears for regular acceleration, and the 335i transmission knows this (has been programmed for it) so it behaves 'smoother' when you decide you want to accelerate sanely. However, in 328i, the transmission has to decide whether it needs to downshift or not, and it does so based on combination of things, including input from the driver (gas pedal) and the speed and the driving mode (D vs. DS) and a bunch of other things I am sure... when you put it in DS and drive it at slower speeds with gentler inputs from yourself, it is confused and it acts like you want it to be acting sporty but you haven't made up your mind yet. If you have it in DS, you need to drive it like you are racing it, and it will behave beautifully in all conditions. If you have it in DS and you come close to an intersection where you need to calm down a bit, then put it in D and you will see it will behave exactly the way you are expecting it to. Once you are done being calm, put it back in DS and enjoy the very nice, crisp, fast gear changes and higher revs. |
08-31-2010, 04:33 PM | #20 | |
Rep 2,200
E9X Picture Game: 8 points: (High visibility jacket; Strip Club; Pizzeria; Sobriety Test; E9x dressed for Halloween, Billiards, Oil Change, Orange Cone)
08-31-2010, 04:54 PM | #21 | |
Burning the midnight oil
29
Rep 479
There are a lot of reasons to like the 328i, but the auto tranny isn't one of them. |
08-31-2010, 05:15 PM | #22 |
Rep 2,446
Oh the irony.
The ZF is a beefed up 6HP19 coded 6HP19TU, which allows 450Nm of torque. The regular 6HP19 is less than that. The GM is a lesser version 6L50 coded 6L45R, which allows ... 450Nm of torque. The ZF is no more solid than the GM. Now ZF's best tranmission (8-sp.) is back to 200ms gear change.... like the GM. I love my GM unit, less the gear shifter that failed on my car (probably the same as the ZF anyway). |
