E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > How do you reset the service indicator?
Reply
      01-11-2007, 04:26 PM   #1
Kraems
Drives: 2006 330i ZPP ZSP 6MT
Hi Everyone,
First post on e90post.com. Just wanted to say this is a great resource for my new/used car. Thanks to all for sharing.
I tried searching the forums and archives before posting this, but couldn't find the answer.
Is there a way to manually reset the service indicator for the oil change? The reason I need/want to do this is because I've imported my car from the US to Canada which voids the free scheduled maintenance for my 2006 E90 330i Sport. A friend of the family works at the local GM dealer, and I trust him a lot more than the local BMW dealership (poor experience with their service department and my mother-in-law's MINI Cooper S) so I had him perform the oil change. The problem is the indicator light still shows red, indicating that an oil change is overdue.
Any ideas?? Thanks in advance.
      01-12-2007, 07:30 AM   #2
txusa03
Drives: TS330iPPSP6MT
hey, welcome aboard. I have not seen anyone figure out a way to reset the service indicator on the e90 as a DIY. I think your best bet at this point is to get the bmw dealer to reset it. If you find a way to do it yourself without the need of a bmw dealer, let us know. This would be very good to know those who plan to keep the car beyond the free maintenance and plan to diy oil change and brake. I think it would be difficult to do it outside dealer because its looks like there are several indicators for service (emission, brake, oil, Insp I, Insp II).
under construction!
      01-12-2007, 08:52 AM   #3
Kraems
Thanks for the reply txusa03.
I'm going to keep searching other boards, and Google to see if someone has posted a way to do this. I did find one post about pressing and holding the trip reset for 10secs, which does bring up a German sub-menu where the clock and outside temp is, but didn't go any further because their instructions didn't match what I was seeing, and I didn't understand the German either!
      01-16-2007, 10:33 PM   #4
irowharderthanyou
irowharderthanyou's Avatar
25
Drives: 330i TiAg
I remember there being a way to reset it. I think it had something to do with holding down the trip distance reset button while in the oil service menu. Maybe someone else can chime in as I have never done it.
2006 330i TiAg - Beige, Step, ZPP, ZCP, Sat. Prep.
      02-23-2007, 12:33 AM   #5
Placey
Placey's Avatar
Drives: 08 Z4 3.0SI
Push start button, to Radio position (not start/run) when check control image disappears and all that is left is current time on the LCD panel of the instrument cluster, press and hold the odometer reset button. After a few seconds, the oil image will come up. Push and hold the "BC" button of the turn signal stalk until it states "Reset?" let go of the button and push the button back in and hold, a little clock will come up, and then it will say 15,000 miles. It now has been reset
      02-23-2007, 09:17 PM   #6
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
Terrific Info!
"Teach the ignorant. Ignore the stupid."
      02-23-2007, 09:25 PM   #7
Kraems
A huge thank-you Placey! This will make keeping my service indicator up to date for any service that I have done outside the dealership a breeze.
Just a note -- I had to turn the car on in order for the oil image to display after holding the odometer reset button. Other than that, the instructions you listed were spot-on! Thanks again.
      02-24-2007, 11:46 AM   #8
Jaws
Jaws's Avatar
Drives: 2006 325i mt
This requires a sticky!!!!
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red
2007 Chev Silverado crew cab Z71
      02-24-2007, 02:27 PM   #9
mbaric
mbaric's Avatar
Croatia
Drives: E90 318i
Yes, make this a sticky.
Great info.
Bayerische Murder Weapon
      02-24-2007, 03:14 PM   #10
txusa03
Great job...this forum :rocks:
How about other services like brake wear and inspection I and II?
under construction!
      02-24-2007, 03:24 PM   #11
worlina
Chief
worlina's Avatar
Drives: 2016 BMW X5 xDrive 35i
I tried this today, however I got some German message something like (kfrtng _ _:_ _ ) . I even got to some kind of test where the the odometer and tachometer turned simultaneously, all the icons came up and the small screen refreshed. It did not work for me, please advice. Thanks.
      02-24-2007, 03:27 PM   #12
txusa03
I know what you are describing, that is the hidden menu in German. You might have skipped a step some where. I have not done this myself coz i dont want to accidentally reset my free oil change indicator (that would blows big time).
under construction!
      02-24-2007, 03:36 PM   #13
Placey
Placey's Avatar
Drives: 08 Z4 3.0SI
Official Way to reset service information data
What you entered is the Instrument Cluster Test funtion screen.
After turning the vehicle to the radio mode, (everything on except the engine), you have to hold the button down AFTER the date/time, temp screen comes up in the LCD screen.
To reset the service information data using the cluster:
• KL-15 on and all Variable displays in cluster off (clock should be displayed)
• Press and hold odometer reset button until CBS pictures display in cluster for about
5 seconds then release
• Use the BC button to scroll through till desired resetable picture is displayed.
• “Reset?” is displayed, Press and hold BC button a picture of a small anaolg clock
runs through its display. When complete, the CBS reset that you chose is reset.
• If you want to insure that the reset was done, you can press the BC button while still
looking at the CBS reset pictogarm and the acknowlegment of reset will be shown
with a check mark in a box
      02-24-2007, 03:37 PM   #14
Ninjaneer
Shadow Warrior
Ninjaneer's Avatar
Drives: '07 335i Sedan
This essentially will push your date out further so it's not something you'd use often, if at all, if I understand it correctly.
In the OP's case he got it done at another dealership so he reset it to keep track of when the next one should be. But in my case for example, I recently did a non-scheduled oil change and told them NOT to reset the pc, thus enabling me to get my scheduled one later for "free."
Sorry if what I'm saying is obvious :P
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods:
PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar
Installing soon: Rear Power Outlets (Happy Robot mod!)
      02-24-2007, 04:00 PM   #15
Placey
Placey's Avatar
Drives: 08 Z4 3.0SI
Yes, this should ONLY be reset as in a case such as Kraems, whenever possible do use the Free Maintenace plan with BMW. Not only will it allow your vehicle to be checked for any problems, but you wont have to pay a thing. Free Wipers, Oil service, Brake fluid flush's, these are all essential to keep your vehicle in premium condition. The information i supplied is only for that rare case such as the one that started this thread. I do work for a dealership myself and take pride in the work i do. Every vehicle that i get for a service gets looked over very well, even when under warranty. I have found many instances where the typical oil change turned into a 4 wheel brake service, axles being replaced due to leaking boots, the occasional oil leak being repaired, many of these problems which were stopped before becoming larger problems, and not only that, all done under warranty.
I know people have had problems with some dealer service dept's, I have seen them happen myself. The information i provide is not to discourage the services being done at the dealership, but as the starter to this thread stated, it was due to an uncommon circumstance that this procedure had to be performed.
Take advantage of the maintenance, no other manufacturer will cover as much as BMW does.
The occasional trip to the dealer can save you a lot of money down the road by finding the problems before they escalate.
      02-24-2007, 04:17 PM   #16
BoostedBMW
BoostedBMW's Avatar
Drives: TiAg E92 335
2003 S2000  [0.00]
Great post... this is very good to know. Placey, what service dept do you work at in NY? I use to deal with Habberstad and Competition before I moved.
-Michael.
Berlina Black S2000 CR is now in the garage
l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l
      02-24-2007, 04:39 PM   #17
Asiann
Got Seoul?
Drives: 2012 535i MSport
2012 BMW 535i  [0.00]
2008 750Li  [0.00]
2006 BMW  [0.00]
Did the same thing and the dealer did not reset the OD allowing for a free oil change later when indicated!
Can you say Alooooha?
[SIGPIC][/SIGPIC]
      02-25-2007, 08:30 AM   #18
Placey
Placey's Avatar
Drives: 08 Z4 3.0SI
I'm w/ Orange County BMW
      02-25-2007, 10:54 AM   #19
c1pinang
Drives: e90 325i
2005 Audi S4  [0.00]
2006 E90 325i  [0.00]
Great post!
One problem though: I had only meant to change the service date in the first place from 11/2006 just to get rid off the service warning light off my dash. Anyhow, 11/2006 was the date I got the bmw service maintenance [at around 15k miles] and I believed the dealer forgot to reset this date and changed it to sometime in 2007.
But along resetting this date, I accidentally reset the oil change menu which now shows that I'll have 15k more miles to go until the second interval. I was trying to find out if I can reduce the 15k interval to let say 12k
My question is: would the BMW system still tell me when is the appropriate time [based on driving condition] to bring the car in for service although I had reset the system earlier without actually changing the oil?
I'd appreciate it if you guys could give me some advice on this
Thanks
      02-25-2007, 04:43 PM   #20
Placey
Placey's Avatar
Drives: 08 Z4 3.0SI
Unfortunately, there is no way to lower the interval time from when you reset it. However, these cars have "oil condition sensors" which allow the service interval to actually set itself. By sensing the condition of the oil, the 15,000 mile service is no longer an exact mileage due to the way different people drive. Therfore, with it only being about 3000 miles difference, i dont think you should be worried, if you had only 1,000 miles left, then i would be a little worried, but that shouldnt be a problem. So, you dont have to be worried, for the fact that it will still tell you when it's time to bring it in for service.
I ahve done services on vehicles with 10,000 miles, and some with 20,000 miles, nowadays its just how people drive.
      02-25-2007, 05:29 PM   #21
txusa03
Not just how ppl drive but it also make a different if they drive in lots of stop & go vs highway.
under construction!
      02-25-2007, 06:46 PM   #22
c1pinang
Drives: e90 325i
2005 Audi S4  [0.00]
Thanks Placey and txUSA03 for your advise!
Reply
e90post
