tyre pressure sensors
09-08-2010, 03:46 PM | #1 |
Rep 322
evnin all.
yes i have searched on here and cant find any specific answers to the problem. I have ps2's on the motor, non rfts. since a huge downpour a week or so ago when i was on the motorway, teh tyre pressure sensor comes on every few days. i have checked the pressures and one did need pumping up, so i pumped it and reset the tyre pressure system. since then, no air has left the tyres, but the ligght keeps coming on. I am thinking that there may be a specific method of re setting the sensor, rather than pressing it for a few seconds and waiting for the tick. have read somewhere it may be alignment, but i think it is more to do with the drive home in some serious rain, when the car did hit a few puddles on the motorway at high speed. any ideas? cheers |
09-08-2010, 04:00 PM | #2 |
Rep 8,972
The pressure monitor uses the ABS sensors, so they are working or you would have more warning lights.
How do you know no air has been lost? are you checking the pressures? Have you reset it properly? sounds ok if you have the tick in the intialising idrive box. |
09-08-2010, 04:01 PM | #3 |
Rep 15,858
Sounds as if you are not setting the system correctly. Do you run the engine, get the tyre check control and get the tick then hold until tick re-appears and drive off to initialise?
HighlandPete |
09-08-2010, 06:36 PM | #4 |
Rep 322
thanks guys. the process for resetting is via the indicator stick, dial the menu,press once, then press again and keep pressed until tick appears. this is a non i drive car.
I know no air has been lost as the light has been on 5 times and after time 1, i have been checking the tyres every day, with a consistant 38 psi. The light comes on every few days irrespective of tyre pressure. All times that i have reset are after about 60-100 miles on mway. I just park up , and put auto gearstick into park, and do the resetting as described above. Is there more to it than that? Thanks Swiller |
09-09-2010, 08:34 AM | #5 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
hmm...i think you should reset it before you even drive the car....
check the pressure in all tyres, then press the reset button....and then drive off... I had some issues aswell.... I recently changed a tyre....(replaced by kwik fit) and i didn't touch the reset ...i just drove off....the light came on after a few miles!!!.... I've reset it, and it hasn't been on since... Do check your tyre pressures every 2-3 days, as these tyre pressure monitors aren't that reliable... |
09-09-2010, 02:10 PM | #6 | |
Rep 683
2010 E90 335i M-Sport, 2005 E90 325i M-Sport, 2003 E60 520i, 2002 E46 330i Sport II, 2000 E46 325i Sport I, 1999 E46 318i, 1998 E46 323i SE, 1996 E36 323i SE, 1996 E34 518i, 1995 E36 320iA, 1994 E36 316i
09-09-2010, 04:28 PM | #7 |
Rep 322
Thanks for replies . All were 38 psi. Took it down kwik fit today, as I got up this morning and the back rear had deflated which is why the indicator came on yesterday. Still doesn't explain why even when tyre pressures ok, it still came on for the previous times. Kwik fit diagnosed a very slow puncture in back rear and pumped front and rears appropriately. They also checked the sensors and stuff to fix any loose connections. Just hope the bugger doesn't come on again, but have a suspicion it will.
09-09-2010, 05:27 PM | #8 | |
Rep 683
09-10-2010, 02:57 PM | #9 |
Rep 322
After a 200 mile necessary geoff (hoon) today, all is well, no warning lights at all. Seems you were spot on Carl. Kwik fit did tell me they set the fronts lower than backs and all was spot on when I checked this morning. I thought the electronics were starting to play up, which has always been a right pita on beemers. So cheers ++. I never realised the pressures were different front and back, and rarely pump em up myself. When I did , that's when it went wrong lol.
09-10-2010, 04:12 PM | #10 | |
Rep 8,972
It only senses a change in wheel speed / pressure since the last reset was done. So if you put the fronts at 40psi and the rears at 20psi and reset it, the system would be quite happy with that until one tire speed / pressure changes. Thats why its vital you reset it every time you adjust pressures or change a tire. |
09-10-2010, 05:02 PM | #11 | |
Rep 683
09-10-2010, 05:22 PM | #12 |
Rep 8,972
That can't be possible IMO? The car only knows reported wheel speed of each wheel, no more. It doesn't know wheel size.
Even if all the wheels were the size of hula hoops they would all have the same rotational speed, and the car only has this wheel speed as a reference so it could not find any fault. Again, change the wheels for tractor tyres and the same goes. It can only be a relative system, if ALL the tyres are equally flat it cannot know they are flat, same goes for over inflated or bald etc. Last edited by doughboy; 09-10-2010 at 05:30 PM.. |
09-11-2010, 08:19 AM | #13 |
Rep 1,135
I think people are getting a bit misled here. BMW calls the system TPMS, tyre pressure monitoring system but it does not monitor the tyre pressures in the UK. It is a different system in the US. The UK system using the ABS sensors, these measure the speed of each wheel. If a wheel is turning at a different speed to another it is assumed that is because it has lost pressure. It is a relative, inferrred measurement. It has no way of knowing the actual pressure. HTH
09-11-2010, 08:36 AM | #14 | |
Rep 15,858
Should help reduce the confusion. We still need to check pressues regularly. HighlandPete |
09-11-2010, 09:16 AM | #15 |
Rep 3,923
has anyone tried the tyrepal monitoring system, am considering this as it gives tyre pressure for each tyre and the temperature, especialy useful if you are running non runflats
09-11-2010, 01:17 PM | #16 |
Rep 1,130
I have the warning coming on every few weeks. Normally after I hit a patch of mud or something and one wheel slips.. then short way down the road it warns me with a red tyre deflated symbol! Scares me and I carefully drive home, check and check again next day and all tyres are fine so I reset it. But it is a rubbish system! VAG one is far superior and tells you which wheel is deflated.
09-11-2010, 03:27 PM | #17 | |
Rep 8,972
So the method it uses isn't too important. |
09-12-2010, 03:59 AM | #19 |
Rep 33
I'm surprised about the need to hold (the I-Drive controller?) until the tick appears - nothing about that in the owner's manual. Is this an undocumented feauture? I'm now concerned mine is not properly initialised either!
09-12-2010, 09:38 AM | #20 | |
Rep 15,858
HighlandPete |
09-12-2010, 09:43 AM | #21 | |
Rep 15,858
HighlandPete |
09-12-2010, 11:48 AM | #22 | |
Rep 33
It says something to the effect of "Init complete" then a picture of all the wheels go green!!!...I'm going to have to go and do that now, just to check! |
