Bluetooth Greyed out & voice command not working
09-13-2010, 07:33 AM | #1 |
Rep 109
Had my battery disconnected briefly yesterday and now Bluetooth isnt working. Bluetooth option in iDrive phone menu is greyed out & voice command isn't working either.
Does anyone have any suggestions? Thanks! Last edited by joelc73; 09-13-2010 at 09:59 AM.. |
09-13-2010, 09:43 AM | #2 | |
Rep 13,023
Your TCU somehow is not powering up, that's where both the Bluetooth and the Voice Control are; try to call Assist as well, I bet that it is not working either. Unplug the TCU -including the MOST connector- and re-plug to see if you can get it back. |
09-13-2010, 09:59 AM | #3 | |
Rep 109
I do actually have iDrive. I tried resetting (holding power button for 25 seconds) but it didn't seem to help. What's strange is, when you pick phone/options in iDrive, the bluetooth check box is unchecked and greyed out. Should I try unplugging the TCU? And BTW, what and where is the TCU? |
09-13-2010, 10:45 AM | #4 | |
Rep 13,023
Can you make an Assist call? |
09-13-2010, 10:55 AM | #5 |
Rep 109
12-05-2011, 04:28 AM | #9 | |
Rep 4
This started happening the moment I started the car after I got it back from a New DMF + CLUTCH Installed... not sure if that could have anything to do with it.
Hey Technic! I need your help! Having the same problem!!! Quote:
Would appreciate any help! So far I've tried.... removing the negative connection to the battery for about 10 minutes... nothing. Should I try for longer? unplugged all connections to the TCU for about an hour and plugged it back in.... still nothing... I'm at a complete LOSS! btw it is an 07 328xi Coupe with idrive, I'm unable to contact BMW assist, and bluetooth communication checkbox is unchecked and all grayed out. Feel free to email me at stevesy710@gmail.com directly or text me at 515-710-1253. Last edited by stevetech; 12-05-2011 at 04:44 AM.. |
12-07-2011, 03:07 AM | #11 | |
Rep 13,023
Another possibility: check the fuses of all the MOST devices in your car (TCU, Logic7 OEM amp, MULF, iPod adapter, CD Changer, etc). One of them could be blown. |
12-18-2011, 12:28 PM | #12 | |
Rep 4
Thanks I have checked all fuses in the glove box and the fuses in the white box up front. No CD Changer. All are fine. Where should I start with? Any idea what part of the MOST ring would even possibly be broken/removed while they put in the new clutch? Last edited by stevetech; 12-18-2011 at 12:42 PM.. |
02-08-2017, 01:42 PM | #14 |
Rep 1
bmw 328xi 2011
The same problem happened to me. Bluetooth grayed out. I didnt disconnect the battery though. What I did to fix it was unplugged USB devices(cable and usb drive) and unplugged aux cable. Bluetooth worked after that, seems like the cable was short circuited and protection mechanism kicked in to save other modules.
12-07-2017, 04:32 PM | #15 |
Rep 8
Same issue. Phone worked perfectly. Took it in for a 'Fault Recall' and when the car was returned the bluetooth was greyed out!
Dealership trying to say it is a hardware failure of an ECU unit. No way... they connected the car diagnostics and either that screwed the bluetooth or they screwed it up somehow when doing the 'Fault Recall' work - maybe they unplugged the battery or they dislodged a wire somewhere and failed to reconnect it. But I do know from connecting an OBDII reader since that there is a fault in the CCC unit (according to Carly but I'm told by someone on e90post that should be the CIC unit as 2011 models do not have a CCC but a CIC) in that: the MASK is not set up correctly. It has an error code: "00E1CF Central Registry is incorrect." Trouble is I don't know what that error code means. Any info on that code from anyone?? |
10-02-2019, 10:11 AM | #16 | |
Rep 9
I've diagnosed the MOST system and I cannot get any signal (optical red light) at the final termination under the dash (E92). I've confirmed there is signal being received up to the satellite radio module, even bypassed it with a MOST bypass loop without any success. Would you happen to know the fuses for each of the modules? Or if you have any other ideas |
