Speaker problem when using AUX
09-19-2010, 11:50 AM | #1 |
Rep 572
Hi,
Ive noticed something with the drivers side sdoor speaker when using the AUX port. When my iPhones plugged in, the drivers side door speaker intermittently fails and it's only the front left playing. If I adjust the balance, it makes no odds. After a while itl come back on and play as normal. It happens when turning, accelerating, braking, but also while stationary in traffic for example. Anyone ever had this? If it was a loose connection, surely it wouldnt do it while stationary? And it's only on AUX. Tried other mp3 players, and other cables too. Cheers |
09-19-2010, 01:18 PM | #2 |
Rep 79
I had this. Was just a dodgy wire/connection between the aux and the cable I was using. Fiddling around with it made the front speakers cut in occasionally or cut out. If you haven't ever taken your door cards off or doors apart it's unlikely to be the speaker wires come loose, and if it only happens with the Aux then it is 100% either what I mentioned, or perhaps the wiring itself for the aux underneath the storage compartment is loose/poorly connected.
09-19-2010, 04:06 PM | #5 |
Rep 572
Nope, no alpine upgrade and I've checked all the connections. I wonder if it's and iPod/iPhone issue when using AUX?
It's going into the dealer tomorrow for engine problems so I'll ask them then about it. |
09-20-2010, 03:43 AM | #6 |
Rep 8,972
Sounds 100% like a poor connection, most probably at the 3.5mm jack socket, you're losing 1 channel momentarily.
If other devices don't do it, then it must be the ipod lead jack, try wiggling it in the socket when you're listening. The aux-in is only a dumb analogue line-in socket, it doesn't know what you are pluggin in it, could be a record player for all it knows, so there can't be any 'compatability' issues with ipod etc. |
09-20-2010, 04:38 AM | #7 |
Rep 2,398
mine does it all the time tho, whatever conn i use
i think a mistake was made when installing the alpine upgrade going to stealers on 29th tho.. should get sorted |
09-20-2010, 12:11 PM | #8 |
Rep 572
Mines is just back from the dealers today.
The typical "We didnt find a problem Sir" was quoted, and I was sent on my way. It's a right pain. Its only started recently, so no idea whats causing it. |
09-20-2010, 12:34 PM | #9 |
Rep 2,398
09-20-2010, 12:53 PM | #10 | |
Panzer
18
Rep 405
10-24-2010, 12:02 PM | #11 |
Rep 572
Still experiencing this issue even after visiting the dealers twice.
Funny tho...when the front right speaker goes wonky, a swift thump to the arm rest on the left hand side or top seems to correct the issue for a while! Surely that would mean a loose connection somewhere? Just don't Understand how or why this would happen. |
11-05-2010, 08:38 AM | #14 |
Rep 572
Just a straight forward 3.5mm jack to 3.5mm jack straight into the AUX port.
I was going to take the centre console out and see if the connection is knackered. |
11-05-2010, 09:17 AM | #15 |
One in the chamber
Rep 211
Those 3.5 to 3.5 are notoriously dodgy on the iPhone. I bought one of these & have had no problems since. Try it before disassembling your console!
http://cgi.ebay.co.uk/3-5mm-Car-Ster...item20b4b30adc |
11-05-2010, 10:20 AM | #17 |
One in the chamber
Rep 211
I'd tried three different 3.5 to 3.5 cables & experienced similar problems to you & generally bad quality sound. Bought one of the dock cables & I've never had any issues since.
For £3.50 its worth a shot Last edited by Jay_Jay; 11-05-2010 at 11:48 AM.. |
11-05-2010, 02:04 PM | #18 |
Panzer
18
Rep 405
11-06-2010, 05:04 AM | #19 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Almost certainally the 3.5mm cable at fault here I would say.
11-06-2010, 03:21 PM | #21 |
112
Rep 5,541
It's certainally where I would start MP!
11-10-2010, 02:55 AM | #22 |
Rep 572
Still no luck! New cable arrived n didn't make a difference! Pretty confused now! Only affects from right, but soon as I play a CD/Radio the speaker works fine!
Smacking the armrest seems to get AUX working too! Anyone any other suggestions? Last edited by Masterplan; 11-19-2010 at 04:05 AM.. |
