Software Update Query
10-13-2010, 10:53 AM | #1 |
Rep 62
Hi All.
Wonder if anyone can shine some light on something before the dealer gets back to me. My car went in today for a software update for the infamous clutch judder (its a 320d). Anyway, it seems to have fixed it for now at least but, my car is now telling me it needs the brakes changed sooner than when it went in, fronts are now in 5000 miles vs 13000 miles before and rears are now 7000 vs 12000 before. Could the update have messed these up, or maybe made the reading more accurate? I'm really confused as when the car when in about 2 weeks ago about the clutch issue (to investigate before the software was available) I was told that my rear pads needed changing soon, but my fronts where fine..... I'm waiting for the dealer to call me back as I want to understand why they are now less than before. Thanks |
10-13-2010, 11:14 AM | #2 |
Rep 62
don't know how to get rid of a thread, but dealers come back, a software glitch apparently, need to take it in again tomorrow to have the original values reset which should take an hour.
10-13-2010, 03:15 PM | #3 |
LSD - No, you're not seeing things
72
Rep 3,302
I wonder about these 'glitches'.
And how many 'dealers' use the excuse to frig down the percentage wear on consumables thinking nobody will notice. And I bet a most wouldn't. Those who do get the 'sorry Sir it must be a bug - bring it back in'. Yeah right. Even with the Bavarian Tech tool, I can set any percentage remaining for service items, so a dealer can do the same. As you can see, I dont trust any of them and this is one reason why. S.
10-14-2010, 04:39 PM | #4 |
Rep 408
Maybe the dealer estimated the actual mileage left on them & programmed it in?
I don't know much about the 320D but how the heck can a software update stop clutch judder?? that ones really got me. |
10-14-2010, 04:49 PM | #5 | |
Rep 235
surely the clutch is hydraulically operated by the clutch pedal which is controlled by your foot?? Clutch judder normally means worn clutch plates etc |
10-14-2010, 04:59 PM | #6 |
Rep 517
The software update will change the revs at the biting point. If you raise the clutch slowly you will see them kick in on their own without you touching the accelerator.
It does help although a physical problem with the clutch/flywheel probably exists |
10-15-2010, 03:33 AM | #7 |
Rep 62
Thanks for your comments, I had a new flywheel and clutch fitted about 20000 miles ago which did seem to fix the judder but only for a few months.
I've had to wait for this later software update as earlier ones only fixed the issue for a short time (there's another thread about it). As for my brake reading, they tried changing the readings back to what they was before but they set to zero! Anyway they then changed the sensors and reset and I'm now at 7000 on the fronts and 12000 rears, can't fault the dealer for trying (was in there 2 hours). As its condition based it 'might' increase apparently when it works out how I drive as everything was cleared in the upgrade. |
10-15-2010, 05:38 AM | #8 | |
72
Rep 3,302
If you know a software flash will wipe the CBS then they bloody well ought to note all the parameters before starting work. Hopefully they guessed more accurately when resetting the oil service marker too. Sloppy....
10-15-2010, 09:51 AM | #9 | |
Rep 1,179
How old and how many miles on the car when they were replaced? Ta. |
10-15-2010, 10:18 AM | #10 |
Rep 62
Hi Ant Man, clutch and flywheel where replaced last June (09) under warranty. Off the top of my head I think I was on about 28000 miles (car had 21000 when I purchased it on AUC) car was registered November 07.
When it went in they said that they needed to take the clutch out to have a look and if it was within tolerances id be charged, but luckily they said it was warped so it was replaced free of charge. This fixed it for a few months but it was niggling from about December last year and got to full annoyance in August time this year which is why it went in again. I had to wait a while for the software to become available. So far so good. Hope this helps |
