HKS BOV Springs
10-14-2010, 05:08 AM | #1 |
Keepin' America Free
72
Rep 1,260
HKS BOV Springs
Hey guys,
I've done a lot of searching and can't find any details on anyone changing the springs in their BOV. They sell different springs for just about every BOV for different pressures, but I haven't seen anyone with an N54 doing it. I have seen that with the HKS SSQV BOV on my car, it is only noticeable if I hit about 4500 RPMs or higher. My question is, has anyone changed the springs on their BOV? I am just wondering if it is possible to get a spring that releases at a lower PSI. Negative comments not needed. TIA.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
10-14-2010, 05:54 AM | #2 |
Rep 238
Drives: F30 335i
do you have a boost gauge? maybe your not making boost till then.
10-14-2010, 11:56 AM | #4 |
72
Rep 1,260
Yea I have a gauge, I'm getting plenty of boost. I mean it's noticeable enough, but only if I get on it a little bit.
I know HKS makes 3 different springs- red (12-18 psi), blue (7-14 psi) and yellow (6-12 psi). All three could technically work for our car, but red is a little big. The rate is simply what pressure is needed to vent, not how much it can hold. I'm just curious as to what springs most people are using.
10-15-2010, 12:52 AM | #6 |
72
Rep 1,260
Thanks man, I have to check what mine has. I'm out of town for work right now but I'm guessing it also has a red.
Anyone using yellow or blue, or the equivalent with a different BOV?
10-15-2010, 01:03 AM | #7 |
Addicted.
43
Rep 1,208
I did not know that there is a spring in the HKS bov? I thought they were piston types with no springs or diaphram (Greddy's horrible design).
#TeamNemesisTX
10-26-2010, 09:16 PM | #8 |
Rep 238
Drives: F30 335i
So, Im going to jack this thread a little bit, I read the box the SSQV came in, and it says thats not a spring load design. I noticed as well, just revving it up in neutral, that it wont open till like 4k. So i looked at the good ole boost gauge that the procede makes, and it says im not making boost til 4k, and even then its not more than 5psi. Driving around/under load, its good, ill make boost depending on how much pedal I give it. Also, when WOT and boost gets up to like 15-16 psi, it sounds like it opens then closes and opens again. Maybe what im hearing is that it starts to open, opens all the way, and then i hear it again when its partialy closed? Any one else have any experiance with this?
