Wheel hop VS wheel spin - issue with suspension or plague of E93
10-15-2010, 12:32 PM | #1 |
Rep 267
Drives: 2007 E93 Alpine white with Red
So I know from my mustang days that if you pop the clutch and get wheel hop, you've got some work to do regarding your control arm bushings, especially if you had a 03-04 cobra with the IRS.
No matter how I manipulate the DTC button, and whether wet or dry, I always get the most violent wheel hop from the dig. Is this typical with these cars, something that the flexy e93 is more pone to, or is there something in my suspension setup that I've got to address?
2007 335I E93 sport package Alpine White. BMS DCI, PROcede V4, ACT street clutch, Michelin Pilot Sport A/S Plus and BT Tool. Pending install of Raceland Downpipes.
10-15-2010, 01:32 PM | #4 |
3442
Rep 79,211
Without serious modifications to the suspension geometry you wont get rid of wheel hop.
http://www.e90post.com/forums/showthread.php?t=387147 I already made a thread about this.... |
10-15-2010, 01:44 PM | #5 |
Rep 1,565
Wheel hop has to do more with the suspension toe angle changing as the wheel gains/loses traction and the suspension travels up/down/forward/backward under acceleration. That is the short version. Bushings are usually the culprit no?
2020 M340i: Dravit Grey Mettalic. Loaded.
10-15-2010, 01:53 PM | #6 |
Rep 267
That would make sense that without a LSD each rear wheel might be trying to walk too far forward than the other when it has traction - so like slick said probably nothing I can do about it unless I do some serious modifications and a LSD. Anyone with a LSD installed reduce their wheel hop?
10-15-2010, 01:58 PM | #7 | |
Rep 1,565
LSD has the same issue, I believe it is caused primarily by the toe changing while the tire grabs traction, LSD won't solve that problem. I think it is the suspension bushing components/rigidity? RTABS etc? Maybe? Rod ends or spherical bearings at joints instead of bushings might be the final cure to remove that flexibility? Guess we won't know until somebody has solved it and what parts it took to solve it. But then again, I don't do burnouts and don't have this issue....
10-15-2010, 02:00 PM | #8 |
Rep 3,012
I Never got wheel hop... I drove a 2nd generation FWD eclipse so I definitely know what it is
I always spun one wheel. Wheelspin was so common sometimes the only way I knew I was getting it was the flashing light on my dash... There was never any violent hopping. This is on an e90. I'd say stiffen up your suspension and make some adjustments. My car never got it even while boosting 15psi |
10-15-2010, 02:08 PM | #9 | |
Rep 3,012
Harry has the solution here:
Summary: We need to have a Pinion snubber. http://www.e90post.com/forums/showpo...7&postcount=17 Quote:
This is odd because I think some of us do not have this problem.. Perhaps there is something else that causes this 'climbing' to happen in some cars. Maybe some people do not have as good of traction? Last edited by klipseracer; 10-15-2010 at 02:14 PM.. |
10-15-2010, 02:24 PM | #10 |
Vengeance is mine, I shall repay
132
Rep 4,656
Toyo R888 + LSD + full m3 parts + Koni DAs w/ custom 900lb rear spring rates will make your e93 VERY happy...trust me
Project: Vengeance[ACM's King of domestics, STOCK:501whp 489wtq | 2.9L whipple stock bottom end: 706whp 688wtq] Callies Compstar motor build:NEXT
10-15-2010, 02:40 PM | #11 | |
Rep 267
So will some of your disposable income being sent my way
10-15-2010, 02:42 PM | #12 |
3442
Rep 79,211
Softer tires is a cheap alternative, it wont be a 100% solution, but it may help.
I remember on my FWD car, Snow tires hooked up nicely, or spun, when I went to an autox compound I had crazy wheel hop with no other changes to suspension. |
10-15-2010, 02:52 PM | #13 | |
Rep 1,565
In this case, he describes it as the housing of the differential and independent suspension, rather the trailing arms etc..that are allowing the toe change leading to the wheel gaining/losing traction and the hopping movement. Solid axel/welding diff to frame seems to be the guaranteed fix according to that post. Bust stiffer/better RTABs can't hurt. It may just raise the limit when it occurs ultimately.
10-15-2010, 03:44 PM | #14 |
Rep 3,012
10-15-2010, 05:52 PM | #15 | |
Rep 1,179
wheel hop is usually a suspension loading problem -- on solid axle cars it easier to restrict the axle housings vertical travel, and reduce the hop by closing the distance the housing travels til it stops. lagging dampning in the rear shock, or weak coil springs can exhibit the same type of problem you are running into .. |
10-15-2010, 06:17 PM | #16 |
132
Rep 4,656
LOL...my wallet is still recuperating from all this tire/suspension madness...lol
